Tom Brough
Quick question for those in the knowhow....
I'm wanting to see my firewall rules via telnet, I've run this command and get this reply..
root@NetgearR7800:/$ uci show /etc/config/firewall
firewall.@defaults[0]=defaults
firewall.@defaults[0].syn_flood='1'
firewall.@defaults[0].input='ACCEPT'
firewall.@defaults[0].output='ACCEPT'
firewall.@defaults[0].forward='REJECT'
firewall.@zone[0]=zone
firewall.@zone[0].name='lan'
firewall.@zone[0].network='lan'
firewall.@zone[0].input='ACCEPT'
firewall.@zone[0].output='ACCEPT'
firewall.@zone[0].forward='REJECT'
firewall.@zone[1]=zone
firewall.@zone[1].name='wan'
firewall.@zone[1].network='wan'
firewall.@zone[1].input='REJECT'
firewall.@zone[1].output='ACCEPT'
firewall.@zone[1].forward='REJECT'
firewall.@zone[1].masq='1'
firewall.@zone[1].mtu_fix='1'
firewall.@forwarding[0]=forwarding
firewall.@forwarding[0].src='lan'
firewall.@forwarding[0].dest='wan'
firewall.@rule[0]=rule
firewall.@rule[0].name='Allow-DHCP-Renew'
firewall.@rule[0].src='wan'
firewall.@rule[0].proto='udp'
firewall.@rule[0].dest_port='68'
firewall.@rule[0].target='ACCEPT'
firewall.@rule[0].family='ipv4'
firewall.@rule[1]=rule
firewall.@rule[1].name='Allow-Ping'
firewall.@rule[1].src='wan'
firewall.@rule[1].proto='icmp'
firewall.@rule[1].icmp_type='echo-request'
firewall.@rule[1].family='ipv4'
firewall.@rule[1].target='ACCEPT'
firewall.@rule[2]=rule
firewall.@rule[2].name='Allow-DHCPv6'
firewall.@rule[2].src='wan'
firewall.@rule[2].proto='udp'
firewall.@rule[2].src_ip='fe80::/10'
firewall.@rule[2].src_port='547'
firewall.@rule[2].dest_ip='fe80::/10'
firewall.@rule[2].dest_port='546'
firewall.@rule[2].family='ipv6'
firewall.@rule[2].target='ACCEPT'
firewall.@rule[3]=rule
firewall.@rule[3].name='Allow-ICMPv6-Input'
firewall.@rule[3].src='wan'
firewall.@rule[3].proto='icmp'
firewall.@rule[3].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
firewall.@rule[3].limit='1000/sec'
firewall.@rule[3].family='ipv6'
firewall.@rule[3].target='ACCEPT'
firewall.@rule[4]=rule
firewall.@rule[4].name='Allow-ICMPv6-Forward'
firewall.@rule[4].src='wan'
firewall.@rule[4].dest='*'
firewall.@rule[4].proto='icmp'
firewall.@rule[4].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
firewall.@rule[4].limit='1000/sec'
firewall.@rule[4].family='ipv6'
firewall.@rule[4].target='ACCEPT'
firewall.@rule[5]=rule
firewall.@rule[5].src='wan'
firewall.@rule[5].proto='igmp'
firewall.@rule[5].target='ACCEPT'
firewall.@rule[6]=rule
firewall.@rule[6].src='wan'
firewall.@rule[6].proto='udp'
firewall.@rule[6].dest='lan'
firewall.@rule[6].dest_ip='224.0.0.0/4'
firewall.@rule[6].target='ACCEPT'
firewall.@include[0]=include
firewall.@include[0].path='/etc/firewall.user'
But that seems to be the general firewall rules only, not the custom ones I've set in the "blocking services" tab on the Gui where I have certain devices blocked from certain ports... Where can I find these on telnet??
