Instant Guard IPsec VPN Log Showing Regular Access Attempts
Ceejus
For the past 7 days now, I've seen what appears to be intermittent access attempts in my Instant Guard log. The most recent from today:
Mar 3 07:47:55 06[NET] received packet: from 45.83.66.29[27647] to 96.x.x.x[500] (336 bytes)
Mar 3 07:47:55 06[ENC] parsed ID_PROT request 0 [ SA ]
Mar 3 07:47:55 06[IKE] 45.83.66.29 is initiating a Main Mode IKE_SA
Mar 3 07:47:55 06[CFG] received proposals: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768
Mar 3 07:47:55 06[CFG] configured proposals: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC_128/AES_CBC_192/AES_CBC_256/AES_CTR_128/AES_CTR_192/AES_CTR_256/CAMELLIA_CBC_128/CAMELLIA_CBC_192/CAMELLIA_CBC_256/CAMELLIA_CTR_128/CAMELLIA_CTR_192/CAMELLIA_CTR_256/3DES_CBC/HMAC_SHA2_256_128/HMAC_SHA2_384_192/HMAC_SHA2_512_256/HMAC_SHA1_96/AES_XCBC_96/AES_CMAC_96/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048, IKE:AES_GCM_16_128/AES_GCM_16_192/AES_GCM_16_256/AES_CCM_16_128/AES_CCM_16_192/AES_CCM_16_256/CHACHA20_POLY1305/AES_GCM_12_128/AES_GCM_12_192/AES_GCM_12_256/AES_GCM_8_128/AES_GCM_8_192/AES_GCM_8_256/AES_CCM_12_128/AES_CCM_12_192/AES_CCM_12_256/AES_CCM_8_128/AES_CCM_8_192/AES_CCM_8_256/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048
Mar 3 07:47:55 06[IKE] no proposal found
Mar 3 07:47:55 06[ENC] generating INFORMATIONAL_V1 request 2439795631 [ N(NO_PROP) ]
Mar 3 07:47:55 06[NET] sending packet: from 96.x.x.x[500] to 45.83.66.29[27647] (56 bytes)
Mar 3 07:47:56 05[NET] received packet: from 45.83.64.14[2490] to 96.x.x.x[500] (336 bytes)
Mar 3 07:47:56 05[ENC] parsed ID_PROT request 0 [ SA ]
Mar 3 07:47:56 05[IKE] 45.83.64.14 is initiating a Main Mode IKE_SA
Mar 3 07:47:56 05[CFG] received proposals: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768
Mar 3 07:47:56 05[CFG] configured proposals: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC_128/AES_CBC_192/AES_CBC_256/AES_CTR_128/AES_CTR_192/AES_CTR_256/CAMELLIA_CBC_128/CAMELLIA_CBC_192/CAMELLIA_CBC_256/CAMELLIA_CTR_128/CAMELLIA_CTR_192/CAMELLIA_CTR_256/3DES_CBC/HMAC_SHA2_256_128/HMAC_SHA2_384_192/HMAC_SHA2_512_256/HMAC_SHA1_96/AES_XCBC_96/AES_CMAC_96/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048, IKE:AES_GCM_16_128/AES_GCM_16_192/AES_GCM_16_256/AES_CCM_16_128/AES_CCM_16_192/AES_CCM_16_256/CHACHA20_POLY1305/AES_GCM_12_128/AES_GCM_12_192/AES_GCM_12_256/AES_GCM_8_128/AES_GCM_8_192/AES_GCM_8_256/AES_CCM_12_128/AES_CCM_12_192/AES_CCM_12_256/AES_CCM_8_128/AES_CCM_8_192/AES_CCM_8_256/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048
Mar 3 07:47:56 05[IKE] no proposal found
Mar 3 07:47:56 05[ENC] generating INFORMATIONAL_V1 request 4055424991 [ N(NO_PROP) ]
Mar 3 07:47:56 05[NET] sending packet: from 96.x.x.x[500] to 45.83.64.14[2490] (56 bytes)
Mar 3 09:52:39 08[NET] received packet: from 58.212.237.74[59330] to 96.x.x.x[500] (216 bytes)
Mar 3 09:52:39 08[ENC] parsed IKE_SA_INIT request 0 [ SA KE No ]
Mar 3 09:52:39 08[IKE] 58.212.237.74 is initiating an IKE_SA
Mar 3 09:52:39 08[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/ECP_384
Mar 3 09:52:39 08[IKE] sending cert request for "C=TW, O=ASUS, CN=ASUS x Root CA"
Mar 3 09:52:39 08[ENC] generating IKE_SA_INIT response 0 [ SA KE No CERTREQ N(CHDLESS_SUP) N(MULT_AUTH) V ]
Mar 3 09:52:39 08[NET] sending packet: from 96.x.x.x[500] to 58.212.237.74[59330] (277 bytes)
Mar 3 09:52:41 07[NET] received packet: from 220.250.10.45[18217] to 96.x.x.x[500] (216 bytes)
Mar 3 09:52:41 07[IKE] received retransmit of request with ID 0, retransmitting response
Mar 3 09:52:41 07[NET] sending packet: from 96.x.x.x[500] to 220.250.10.45[18217] (277 bytes)
Mar 3 09:53:09 06[JOB] deleting half open IKE_SA with 58.212.237.74 after timeout
Mar 3 12:25:42 06[NET] received packet: from 167.248.133.53[42805] to 96.x.x.x[500] (336 bytes)
Mar 3 12:25:42 06[ENC] parsed ID_PROT request 0 [ SA ]
Mar 3 12:25:42 06[IKE] 167.248.133.53 is initiating a Main Mode IKE_SA
Mar 3 12:25:42 06[CFG] received proposals: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768, IKE:3DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_768, IKE:DES_CBC/HMAC_MD5_96/PRF_HMAC_MD5/MODP_1024, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_768, IKE:DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Mar 3 12:25:42 06[CFG] configured proposals: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024, IKE:AES_CBC_128/AES_CBC_192/AES_CBC_256/AES_CTR_128/AES_CTR_192/AES_CTR_256/CAMELLIA_CBC_128/CAMELLIA_CBC_192/CAMELLIA_CBC_256/CAMELLIA_CTR_128/CAMELLIA_CTR_192/CAMELLIA_CTR_256/3DES_CBC/HMAC_SHA2_256_128/HMAC_SHA2_384_192/HMAC_SHA2_512_256/HMAC_SHA1_96/AES_XCBC_96/AES_CMAC_96/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048, IKE:AES_GCM_16_128/AES_GCM_16_192/AES_GCM_16_256/AES_CCM_16_128/AES_CCM_16_192/AES_CCM_16_256/CHACHA20_POLY1305/AES_GCM_12_128/AES_GCM_12_192/AES_GCM_12_256/AES_GCM_8_128/AES_GCM_8_192/AES_GCM_8_256/AES_CCM_12_128/AES_CCM_12_192/AES_CCM_12_256/AES_CCM_8_128/AES_CCM_8_192/AES_CCM_8_256/PRF_HMAC_SHA2_256/PRF_HMAC_SHA2_384/PRF_HMAC_SHA2_512/PRF_AES128_XCBC/PRF_AES128_CMAC/PRF_HMAC_SHA1/CURVE_25519/CURVE_448/ECP_256/ECP_384/ECP_521/ECP_256_BP/ECP_384_BP/ECP_512_BP/MODP_3072/MODP_4096/MODP_6144/MODP_8192/MODP_2048
Mar 3 12:25:42 06[IKE] no proposal found
Mar 3 12:25:42 06[ENC] generating INFORMATIONAL_V1 request 630577843 [ N(NO_PROP) ]
Mar 3 12:25:42 06[NET] sending packet: from 96.x.x.x[500] to 167.248.133.53[42805] (56 bytes)
Mar 3 12:25:42 05[NET] received packet: from 167.248.133.53[56982] to 96.x.x.x[500] (392 bytes)
Mar 3 12:25:42 05[ENC] parsed IKE_SA_INIT request 0 [ SA KE No ]
Mar 3 12:25:42 05[IKE] 167.248.133.53 is initiating an IKE_SA
Mar 3 12:25:42 05[CFG] selected proposal: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_3072
Mar 3 12:25:42 05[IKE] DH group MODP_768 unacceptable, requesting MODP_3072
Mar 3 12:25:42 05[ENC] generating IKE_SA_INIT response 0 [ N(INVAL_KE) V ]
Mar 3 12:25:42 05[NET] sending packet: from 96.x.x.x[500] to 167.248.133.53[56982] (58 bytes)
Mar 3 12:25:42 08[NET] received packet: from 167.248.133.53[59685] to 96.x.x.x[500] (680 bytes)
Mar 3 12:25:42 08[ENC] parsed IKE_SA_INIT request 0 [ SA KE No ]
Mar 3 12:25:42 08[IKE] 167.248.133.53 is initiating an IKE_SA
Mar 3 12:25:42 08[CFG] selected proposal: IKE:3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_3072
Mar 3 12:25:42 08[IKE] sending cert request for "C=TW, O=ASUS, CN=ASUS x Root CA"
Mar 3 12:25:42 08[ENC] generating IKE_SA_INIT response 0 [ SA KE No CERTREQ N(CHDLESS_SUP) N(MULT_AUTH) V ]
Mar 3 12:25:42 08[NET] sending packet: from 96.x.x.x[500] to 167.248.133.53[59685] (561 bytes)
Mar 3 12:26:12 06[JOB] deleting half open IKE_SA with 167.248.133.53 after timeout
This looks highly suspicious to me. The only device I have set up to access Instant Guard is my phone, which I have not yet used Instant Guard on. I can't possibly think of any other valid reason for this activity beyond someone out there attempting to gain unauthorized access into my LAN through Instant Guard though perhaps there is a logical explanation here?
Normal port scanning. Welcome to the internet.
So bad actors finding the IKE and NAT-T ports open during port scans in other words. Reason to be concerned? I suppose I could just shut down IPsec altogether since I already use OpenVPN and Wireguard. Wanted to keep all three running as backup options.
F Trick to getting ipsec working in windows 11? VPN 1
