lluke
Hi All,
in the past, I configured 2 different IPSec VPN Servers to join the home network while on the go with the following setup:
I'm pretty sure it worked on Merlin firmware until a couple of versions ago (not sure which one unfortunately), but now I see the internet routed through the VPN also using Server #1.
Checking (from here) the DNS Server identified while running Server #1 and #2, I get in both cases the public IP of the router (expected only for Server #2 since I run unbound in my setup).
Is the scenario I'm looking for still feasible and supported by the Merlin firmware? If so, should I add any other setting/rule to get it working as expected?
PS: my setup is an RT-AC86U currently on AsusWRT Merlin 386.12 using unbound as DNS Server running directly on the router.
Thanks in advance for the support!
- Server #1: just to connect to internal lan(s), achieved by leaving the "DNS Server" entries empty from the Advanced Settings of the VPN Server configuration page
- Server #2: to fully route the internal lan(s) and internet traffic, achieved by specifying the router's internal IP on the "DNS Server 1" entry from the Advanced Settings of the VPN Server configuration page
