Entware iptables no chain/target/match and tcpdump problems
akminer
AX56U v1 running 388 merlin and entware
tech1@RT-AX58U-02A8:/tmp/home/root# iptables -t mangle -A PREROUTING -d 192.168.50.20 -j TEE --gat
eway 192.168.50.175
iptables: No chain/target/match by that name.
tcpdump only gives me traffic to 192.168.40.4 which i believe is the router itself, and nothing else. I have the same exact output on an AX82U 388 gnuton
I've tried all previous working commands with similar results.
tech1@RT-AX58U-02A8:/tmp/home/root# iptables -I PREROUTING -t mangle -j ROUTE --gw 192.168.50.175
--tee
root# modprobe xt_TEE
modprobe: module xt_TEE not found in modules.dep
This was all working on an AC5300, no other commands were needed.
A recent change by Asus causes the TEE module to be disabled at build time for some platforms. I will have to adjust the build process to ensure it still gets compiled.
Does the AX11000 PRO have it disabled?
All models were probably affected, since 388.3 or 388.4 (I forgot exactly which used the GPL merge that caused the issue).
