Curious if irqbalance would improve performance on Asuswrt-Merlin. It’s available for openwrt, but doesn’t seem to be on opkg packages. Although I could probably compile it from git. It’s primarily used for servers and well it would potentially increase network performance it would sacrifice general performance and power saving… or so I’ve read.
“Irqbalance is a daemon to help balance the cpu load generated by interrupts across all of a systems cpus. Irqbalance identifies the highest volume interrupt sources, and isolates each of them to a single unique cpu, so that load is spread as much as possible over an entire processor set, while minimizing cache miss rates for irq handlers.”
