Is there any way to set additional Dropbear startup options?
Weblee2407
I have noticed a couple of issues with the SSH service Dropbear on my GT-AX6000
The ssh session doesn't time out, AND I have had sessions on my Ubuntu, Windows laptop, iPad and iPhone all at once without any grumbling. (apps for iStuff are using keep alive)
I was running TOP for another issue and saw the dropbear init string (if that's what it's called) -
it uses the -s (disable password logins) -j (disable local port forwarding) -k (disable remote port forwarding) options
Didn't find a session count limit option, "chicken and the egg" type of question but how could I possibly add -I idle_timeout
Post in thread 'Replace Dropbear SSH with OpenSSH.'
https://www.snbforums.com/threads/replace-dropbear-ssh-with-openssh.84590/post-835778
Found this which gives me an idea - maybe a cron job to start dropbear with an idle timeout after I kill the primary process
dropbear help confirms the default is no timeout. Can’t figure out how the FW does timeouts.
is anyone on this revision getting timed out per the sssh screen setting?
Ahhhhh! Thanks...
Sooooo - Im looking at another reset to see if it works then...
