LACP on AC87
initrd
Is anyone successful on getting LACP to work on AC87 ?
I am trying to run the script in
https://github.com/RMerl/asuswrt-merlin/wiki/Link-Aggregation
I am able to create bond successfully:
ASUSWRT-Merlin RT-AC87U_3.0.0.4 Sun Jul 27 01:36:11 UTC 2014
admin@RT-AC87R-22E0:/tmp/home/root# /jffs/scripts/LinkAgg 3 4
Bond Created Successfully
However, when I connect it to my switch, the router goes crazy and becomes unresponsive, the 5G is affected and goes to channel 0
Here is the dmesg output:
device vlan1 entered promiscuous mode
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
br0: topology change detected, propagating
br0: port 2(eth1) entering forwarding state
br0: port 1(vlan1) entering forwarding state
gro enabled with interval 2
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ADDRCONF(NETDEV_UP): tun21: link is not ready
device tun21 entered promiscuous mode
ADDRCONF(NETDEV_CHANGE): tun21: link becomes ready
bonding: Ethernet Channel Bonding Driver: v3.7.0 (June 2, 2010)
bonding: Warning: either miimon or arp_interval and arp_ip_target module parameters must be specified, otherwise bonding will not detect link failures! see bonding.txt for details.
bonding: bond0: setting mode to 802.3ad (4).
bonding: bond0: Setting LACP rate to fast (1).
ADDRCONF(NETDEV_UP): bond0: link is not ready
8021q: adding VLAN 0 to HW filter on device bond0
bonding: bond0: Setting MII monitoring interval to 100.
bonding: bond0: Adding slave vlan3.
bonding: bond0: enslaving vlan3 as a backup interface with an up link.
bonding: bond0: Adding slave vlan4.
bonding: bond0: enslaving vlan4 as a backup interface with an up link.
device bond0 entered promiscuous mode
device vlan3 entered promiscuous mode
device vlan4 entered promiscuous mode
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
br0: port 3(bond0) entering forwarding state
device eth1 left promiscuous mode
br0: port 2(eth1) entering disabled state
wl_module_init: passivemode set to 0x0
wl_module_init: txworkq set to 0x1
eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.86 (r456083)
br0: received packet on vlan1 with own address as source address
net_ratelimit: 16387 callbacks suppressed
net_ratelimit: 29620 callbacks suppressed
net_ratelimit: 23805 callbacks suppressed
net_ratelimit: 23953 callbacks suppressed
net_ratelimit: 21095 callbacks suppressed
net_ratelimit: 20954 callbacks suppressed
net_ratelimit: 20153 callbacks suppressed
__initrd
that script was designed for the N66U afaik, it will need to be modified for your ac87
ie, the physical ports for your router are probably something like:
0 1 2 3 - 4 - 5, logically
1 2 3 4 - WAN - 5 (cpu), physical
whereas that script was designed for mips with
1 2 3 4 - 0 - 8, logically for
1 2 3 4 - WAN - 8, physical
Thanks Sinshiva.
Could you please do a little more hand holding ? :D Could you please let me know what changes i need to do ?
__Initrd
Try using port 1 and 2. Port 4 is actually on a separate internal switch.
yeah, I created the script for AC66U mips
might be a good idea to reboot, and leave the ports untouched
then run
robocfg show
that way you can see how the router is set up to begin with
Tried using 1 & 2, the router does not go bonkers but LACP does not work and 5G drops (Attached screenshot)
  • 5G_Drop.pdf
then run
robocfg show
admin@RT-AC87R-22E0:/tmp/home/root# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: xx:xx:xx:xx:xx:xx
Port 1: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 2: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: xx:xx:xx:xx:xx:xx
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 5 8t
2: vlan2: 0 8t
1045: vlan1045: 0t 2 4 5t 7 8u
1046: vlan1046: 0 1 2t 3
1047: vlan1047: 0t 1 2 3 7t 8t
1099: vlan1099: 1t 7
1100: vlan1100: 1t 5t 7 8t
1101: vlan1101: 1 2t 4t 7t 8u
1102: vlan1102: 3 4 5 7t 8t
1103: vlan1103: 5t 8t
admin@RT-AC87R-22E0:/tmp/home/root# /jffs/scripts/LinkAgg 1 2
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: XX:XX:XX:XX:XX
Port 1: DOWN enabled stp: none vlan: 3 jumbo: off mac: 00:00:00:00:00:00
Port 2: DOWN enabled stp: none vlan: 4 jumbo: off mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: XX:XX:XX:XX:XX
1: vlan1: 3 4 8t
2: vlan2: 0 8t
3: vlan3: 1 8t
4: vlan4: 2 8t
If 5G drops then it means port 3 and 4 are actually the correct ones to use.
then run
robocfg show
The RT-AC87U is a special case. One of the four ports is actually from the Quantenna SoC, and won't be properly reported by either "et" or "robocfg".
it could be something to due with which ports are tagged, and which are not, etc ...
of with the Quantenna piece of the puzzle, this might not be easy
I'd still recommend running robocfg show
so at least you have part of the picture
then maybe RMerlin knows how to find the quantenna bits of info
the script makes some assumptions of tagged and untagged ports, vlan handling etc ...
Switch: enabled
2: vlan2: 0 8t
Switch: enabled
1: vlan1: 3 4 8t
2: vlan2: 0 8t
3: vlan3: 1 8t
4: vlan4: 2 8t
First thing I notice, my god there's a lot of vlan's on this device
ok next
see normal
2: vlan2: 0 8t
but after running script
1: vlan1: 3 4 8t
2: vlan2: 0 8t
3: vlan3: 1 8t
4: vlan4: 2 8t
But it probably should be
1: vlan1: 3 5 8t
2: vlan2: 0 8t
3: vlan3: 1 8t
4: vlan4: 2 8t
I also suspect something quantanna related is probably needed as well
I'm not going to be editing the script for this, but you can look through it and easily see what's happening
1. selected ports are removed from vlan1
2. create separate vlan for each port selected
3. create bond
4. set up permissions
Those bogus VLANs at the bottom don't exist. It's just that I don't know a way to properly validate if VLANs actually exist on the 5011x switch.
Thanks KAD, Merlin.
I tried various combinations to enable lacp and dint succeed :-( Dunno if I need to return this and go for an AC68. Before I do that could you guys please let me know iff its possible to have lacp on this routers ??? I can wait and try more if its possible.....
__init
is it possible on this device? I don't know. I don't have one to test with
I can tell you for sure, than unless you modify my script, the script will not work on this device
the script assumes the ports are 1 2 3 4 8t
but your device is 1 2 3 5 8t
I suspect LACP might work on ports 1 & 2
but to do it correctly, you'll have to do all the set up manually
Thanks KAD, Merlin.
If I were you I'd be patient. Look at what's written between the number 1 and 2 of the port numbers at the back of your RT-AC87U - that's probably something still in Asus's pipeline.
that's right, you mentioned that before
I'm interested to see if asus does anything with that
and if they choose to backport any of it to older devices
Update on LAG/LACP/802.3ad on RT-AC87U...
Hi everyone, any updates on 802.3ad on the RT-AC87U? I tried asking the local support office and those level 1 tools do not even know what 802.3ad is, much less know that their products do or don't support it... :(
D Solved Samba, LACP & WireGuard. Question. Asuswrt-Merlin 5
D Solved Lacp Asuswrt-Merlin 11
