Linux NASes and USB3 hub
stevech
Part of the Furniture
I suspect this is endemic to Linux-based NASes so....
My DS212 NAS (latest DSM OS) won't discover and mount a USB3 drive plugged into a USB3 hub that is connected to the NAS. I tried 3 different brands of hubs and 2 disks. It's as if there's no device driver for USB3 hubs?
Same hubs/drives work OK with Win 7.
Anyone tried this?
USB 3.0 hubs require specific kernel support. It's possible that NAS manufacturer don't enable that support when they build their kernel.
In short: USB hubs require driver support.
CHeck to see if the kernel module is loaded - ssh into the box...
should see something similar to below (I don't have any externals attached at the moment)
# lsmod | grep hci
xhci_hcd 132303 0 - Live 0xffffffffa002a000
uhci_hcd 23151 0 - Live 0xffffffffa0018000
ehci_pci 3904 0 - Live 0xffffffffa0014000
ehci_hcd 56821 1 ehci_pci, Live 0xffffffffa0000000
and then
# lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc.
Bus 001 Device 004: ID 125f:601a A-DATA Technology Co., Ltd.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0617 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
With on USB3 hub plugged in. Nothing plugged into hub.
Here's what I got
/$ lsmod | grep hci
etxhci_hcd 62273 0
ohci_hcd 16271 0
xhci_hcd 55286 0
ehci_hcd 31532 0
usbcore 136085 8 usbhid,usblp,usb_storage,etxhci_hcd,ohci_hcd,xhci_hcd,ehci_hcd
/$ lsusb
-sh: lsusb: not found
I unplugged the hub.
lsmod gave the same list. Hub not recognized?
The kernel module is loaded, so that solves that...
Only thing I could suggest perhaps is to tail the logs, and plug the hub in and see what the kernel does..
tail -f /var/log/messages perhaps (depends on where synology is keeping the logs at...)
