some.jimmy
I've decided to post my request looking for a help from you, the great and wise nation of SNB.
I currently have Asus RT-AC5300 router wired to my cable modem. Looking for a sufficient node to abovementioned model to have the best iMesh I can have from my 500 Mb/s connection. Unfortunately I cannot make a wired blackhaul between two of the routers, just wireless. iMesh would be placed on one level flat, within 30-40 meters between both routers, withwalls and another wifi nets existing around the apartment.
Going trough SNB forums and other links I think about RT-AX55, RT-AX56U, RT-AC86U, RT-AC68U, RT-AX68U and RT-AX86U (less likely due to high pricing).
I thought of having RT-AC530 as a primary router and one of above as a node.
What would you recommend or suggest? I would appreciate any answer.
Best,
S.J
Best,
S.J
