Deepcuts
[SOLVED] nslookup time out
Solution: http://forums.smallnetbuilder.com/showpost.php?p=150530&postcount=8
Hello
Using RT-AC68U with firmware 376.48.1 (Merlin)
Local connection to the router using WiFi USB stick from TP-LINK, model TL-WN821N.
Using IPv4 and IPv6.
Connection is PPPoE with both IPv4 and IPv6 dynamic addresses.
PC using Windows 8.1 x64
Almost everything is working good except nslookup and plenty of "Resolving host..." 2 seconds delay in Chrome when I type in a new address.
I have been reading lots of topics about people having nslookup problems but none of the suggested fixes worked for me.
The problem
A simple nslookup:
C:\Windows\System32>nslookup
DNS request timed out.
timeout was 2 seconds.
Default Server: UnKnown
Address: 2a02:2f0a:c074:1d00:e23f:49ff:fe95:6a98
Notice the timeout?
No matter what server I setup in nslookup, nothing gets resolved.
> server 8.8.8.8
Default Server: [8.8.8.8]
Address: 8.8.8.8
> smallnetbuilder.com
Server: [8.8.8.8]
Address: 8.8.8.8
*** Request to [8.8.8.8] timed-out
My ipconfig /all is:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Qualcomm Atheros AR7015 Wireless Network Adapter
Physical Address. . . . . . . . . : F8-D1-XX-B6-XX-11
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2a02:2f0a:c074:1d00:e138:f197:807d:f199(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:2f0a:c074:1d00:4924:f475:c2f3:daee(Preferred)
Link-local IPv6 Address . . . . . : fe80::e138:f197:807d:f199%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.15(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, November 12, 2014 7:22:14 PM
Lease Expires . . . . . . . . . . : Thursday, November 13, 2014 7:22:18 PM
Default Gateway . . . . . . . . . : fe80::e23f:49ff:fe95:6a98%4
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 133746961
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-F4-DD-C8-68-XX-CA-28-XX-38
DNS Servers . . . . . . . . . . . : 2a02:2f0a:c074:1d00:e23f:49ff:fe95:6a98
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ping works fine, with a small 1 second delay before IP to name resolution:
C:\Windows\System32>ping smallnetbuilder.com
Pinging smallnetbuilder.com [216.14.113.203] with 32 bytes of data:
Reply from 216.14.113.203: bytes=32 time=74ms TTL=52
Reply from 216.14.113.203: bytes=32 time=68ms TTL=52
Reply from 216.14.113.203: bytes=32 time=78ms TTL=52
Reply from 216.14.113.203: bytes=32 time=94ms TTL=52
Ping statistics for 216.14.113.203:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 68ms, Maximum = 94ms, Average = 78ms
Doing a trace:
C:\Windows\System32>tracert smallnetbuilder.com
Tracing route to smallnetbuilder.com [216.14.113.203]
over a maximum of 30 hops:
1 1 ms 1 ms <1 ms router.asus.com [192.168.1.1]
2 2 ms 2 ms 2 ms 10.0.0.1
3 2 ms 2 ms 2 ms 10.30.0.81
4 3 ms 2 ms 2 ms XXX
5 32 ms 31 ms 31 ms XXX
6 36 ms 38 ms 47 ms XXX
^C
Short version:
Internet works, ping works, tracert works.
nslookup does not work.
Browsing to a new web address has a small delay with "Resolving host". Subsequent tries to the same address will not have the delay.
What I tried:
Reset the router to factory defaults.
ipconfig /flushdns
ipconfig /registerdns
Disabling IPv6 on router and Windows
Setting manual DNS on router and PC (8.8.8.8 and 8.8.4.4)
Changing the binding order of IPv4 (1st) and IPv6 (2nd) in Windows
Restarting PC after each change
Disabling firewall, AV on PC
Latest updates for Windows on fresh install.
I am out of ideas.
I would not mind nslookup not working too much, but all internet related functions seem to have a small delay, more pronounced on web browsing.
Please throw some fresh ideas at me.
Hello
The problem
A simple nslookup:
Notice the timeout?
> server 8.8.8.8
Address: 8.8.8.8
> smallnetbuilder.com
Server: [8.8.8.8]
Address: 8.8.8.8
192.168.1.1
192.168.1.1
Doing a trace:
^C
Short version:
What I tried:
ipconfig /flushdns
I am out of ideas.
