NVRAM NVRAM Save/Restore Utility Update
Xentrk
Part of the Furniture
NVRAM Save/Restore Utility Update ~ version 30.4.0 18-November-2020
Updated nvram-merlin.ini file to include missing nvram variables from John's Fork. The primary vars of interest are vpn_clientX_custom fields along with a handful of other nvram variables. I also created a section of NVRAM parms that were unique to the fork.
I also fixed the issue where the chmod was not working correctly when an updated program was downloaded.
If you are an Asuswrt-Merlin user, the code will ignore the nvram parms unique to the fork. To speed up processing, you can also comment out the line below by adding a # sign in nvram-merlin.ini file (line 2266).
#[John's Fork NVRAM Parms]
Updated from amtm (u and uf) on both occasions update looked fine, however amtm still reporting Version 30.3.0
All files look to have updated
admin@RT-AX88U-5050:/tmp/mnt/Router/nsru# ls -l
drwxrwxrwx    4 admin    root          4096 Sep  2 09:35 backup
-rwxr-xr-x    1 admin    root           823 Nov 18 16:26 clear-maclist.sh
-rwxr-xr-x    1 admin    root         10382 Nov 18 16:26 jffs-restore.sh
-rwxr-xr-x    1 admin    root         10120 Nov 18 16:26 nvram-excp-merlin.sh
-rwxr-xr-x    1 admin    root          3288 Nov 18 16:26 nvram-hnd-migr.sh
-rw-rw-rw-    1 admin    root         37541 Nov 18 16:26 nvram-merlin.ini
-rwxr-xr-x    1 admin    root         15841 Nov 18 16:26 nvram-restore.sh
-rw-rw-rw-    1 admin    root          1510 Nov 18 16:26 nvram-sample.ini
-rwxr-xr-x    1 admin    root         40866 Nov 18 16:26 nvram-save.sh
-rwxr-xr-x    1 admin    root          1074 Nov 18 16:26 nvram-user-sample.sh
-rw-rw-rw-    1 admin    root           514 Sep  2 09:35 nvram-util.log
-rwxr-xr-x    1 admin    root          3295 Nov 18 16:26 save-mynvram.sh
but when I ran nvram-save.sh, I get
nvram-save.sh: Saving RT-AX88U settings from firmware 384.19_0
nvram-save.sh: Using standard NVRAM variable file: nvram-merlin.ini Version=30.4.0
nvram-save.sh: Running in Backup Mode
nvram-save.sh: WARNING: nvram-excp-merlin.sh is mismatched version
I'm running the utility today after updating from amtm and at the beginning of the backup on John's Fork I get the error below. Is this something I should be concerned with? Thanks
@archiel there is one more update to do... Look at the menu again.
I'll get rid of that message. It is left over from the legacy code. Please ignore it.
I updated the version number in nvram-excp-merlin.sh to eliminate the message. All of the scripts with version numbers have been updated to match each other, even if there were no code changes to the individual scripts. I hate bumping a version of code if there were no changes to it. But I still need an overall version number for the project to manage overall updates.
I may remove the version check feature. It may have been necessary when the original project was hosted on Google Drive and one had to download files individually.
The message regarding nvram-excp-merlin.sh has gone but even after updating the NSRU screen in amtm shows 30.3.0
and the main amtm menu shows
As @L&LD said in a post above - take another look at the text menu - try option 5 to update the NVRAM save restore utility .... you will find that updates the version number and the utility.
