I've recently moved into a 2-story house that isn't wired. I'm going to be running CAT6 to each room and am trying to decide on how many drops for each room.
Because of that I'm wondering which is the best method; every room to have multiple home runs to a single, large switch in the basement or I place switches strategically throughout the house to provide multiple connections to each area. Every room would have a wall plate with female jacks.
This doesn't necessarily mean a switch per room, but I'd be using a switch where multiple connections are required.
I know it's just as much effort to run 12 cables as it is to run 1 but if everything is home-run the switch will need to have about 24 ports which is not common in household equipment or expensive. However, I could get multiple 5 or 8-port gigabit routers for under $30 each.
I'm just looking for opinions on the pros and cons of each.
