Hi I am using an ASUS AC RT68U router flashed with asus-Merlin 378.55_0.
I have setup LiquidVPN modulating server on port 9201 and it works well for a few hours. then disconnects and never re-connects. Reconnecting just errors, reboot and restart VPN is only thing that works.
I notice two things from the logs:
1. There is an authentication failure but I don't understand why.
2. The logs suddenly start logging as 1 Jan 0:00:00:00 after VPN disconnects.
Any help greatly appreciated as at the moment my VPN is unusable for more than a few hours and does not restart.
Cheers,
Omegadcuk
Oct 8 06:19:48 openvpn[4355]: SENT CONTROL [titan]: 'PUSH_REQUEST' (status=1)
Oct 8 06:19:48 openvpn[4355]: AUTH: Received control message: AUTH_FAILED
Oct 8 06:19:48 openvpn[4355]: SIGTERM received, sending exit notification to peer
Oct 8 06:19:40 openvpn[4355]: VERIFY OK: depth=1, C=US, ST=MI, L=Livonia, O=LiquidVPN, OU=Certificate Server, CN=LiquidVPN CA, name=LiquidCA, emailAddress=support@liquidvpn.com
Oct 8 06:19:40 openvpn[4355]: Validating certificate key usage
Oct 8 06:19:40 openvpn[4355]: ++ Certificate has key usage 00a0, expects 00a0
Oct 8 06:19:40 openvpn[4355]: VERIFY KU OK
Oct 8 06:19:40 openvpn[4355]: Validating certificate extended key usage
Oct 8 06:19:40 openvpn[4355]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct 8 06:19:40 openvpn[4355]: VERIFY EKU OK
Oct 8 06:19:40 openvpn[4355]: VERIFY OK: depth=0, C=US, ST=MI, L=Livonia, O=LiquidVPN, OU=Certificate Server, CN=titan, name=LiquidCA, emailAddress=support@liquidvpn.com
Oct 8 06:19:45 openvpn[4355]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Oct 8 06:19:45 openvpn[4355]: Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Oct 8 06:19:45 openvpn[4355]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Oct 8 06:19:45 openvpn[4355]: Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Oct 8 06:19:45 openvpn[4355]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Oct 8 06:19:45 openvpn[4355]: [titan] Peer Connection Initiated with [AF_INET]89.238.129.78:9201
Oct 8 06:19:54 openvpn[4355]: SENT CONTROL [titan]: 'PUSH_REQUEST' (status=1)
Oct 8 06:19:54 openvpn[4355]: SIGTERM[soft,exit-with-notification] received, process exiting
Oct 8 06:38:19 dnsmasq-dhcp[1274]: DHCPREQUEST(br0) 192.168.1.29 54:e4:3a:68:48:df
Oct 8 06:38:19 dnsmasq-dhcp[1274]: DHCPACK(br0) 192.168.1.29 54:e4:3a:68:48:df Davids-iPhone
Jan 1 00:00:14 syslogd started: BusyBox v1.20.2
Jan 1 00:00:14 kernel: klogd started: BusyBox v1.20.2 (2015-07-16 23:17:03 EDT)
Jan 1 00:00:14 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Thu Jul 16 23:26:07 EDT 2015
Jan 1 00:00:14 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (A
RMv7), cr=10c53c7f
Cheers,
Omegadcuk
