smyr
Hi.
I read several guides how to setup PIA in OpenWrt and everything is fine until I try to install this package:
root@OpenWrt:~# opkg install openvpn-openssl luci-app-openvpn
Installing openvpn-openssl (2.3.6-5) to root...
Downloading http://downloads.openwrt.org/chaos_...ges/base/openvpn-openssl_2.3.6-5_brcm47xx.ipk.
Installing kmod-tun (3.18.23-1) to root...
Downloading http://downloads.openwrt.org/chaos_...packages/base/kmod-tun_3.18.23-1_brcm47xx.ipk.
Installing liblzo (2.08-1) to root...
Downloading http://downloads.openwrt.org/chaos_...s74k/packages/base/liblzo_2.08-1_brcm47xx.ipk.
Installing libopenssl (1.0.2g-1) to root...
Downloading http://downloads.openwrt.org/chaos_...ackages/base/libopenssl_1.0.2g-1_brcm47xx.ipk.
Installing zlib (1.2.8-1) to root...
Downloading http://downloads.openwrt.org/chaos_...ps74k/packages/base/zlib_1.2.8-1_brcm47xx.ipk.
Unknown package 'luci-app-openvpn'.
Configuring kmod-tun.
Configuring liblzo.
Configuring zlib.
Configuring libopenssl.
Configuring openvpn-openssl.
Collected errors:
* opkg_install_cmd: Cannot install package luci-app-openvpn."
Thats where I get stuck. I did a vpn* search and luci-app search, openvpn but nothing. Yes, sure I can set it up without a GUI like Luci but for me to keep it simple it has to be through a menu option like services as it should have been if this command worked.
So what to do now? I *really* wanna try OpenWrt because (admit it or not) its the most advanced firmware with no limits.... you can add whatever you want. Sure I got dd-wrt and its working fine... I will also try Tomato and Pia later on.
Help! If I cant get this into Luci (or any gui) I will have to change firmware. The router is by the way a Linksys E4200 v1 running OpenWrt Chaos Calmer 15.05.1 / LuCI 15.05-188-g87e9837. Latest version.
/smyr
Configuring liblzo.
Configuring zlib.
Collected errors:
/smyr
