during my experimentations with trying to get tunnelbroker ipv6 working, I encountered a strange issue where I had been able to ping ip6 from PC to my asuswrt.
Then at some point my ip6 ping stopped working and I could no longer ping ip6 to or from the router.
After much further experimentation I disabled the ip6 firewall.
Now my ip6 pings were working again for my local network devices.
I messed around some more, turned ip6 firewall back on, and my ip6 pings continued.
Later I was doing something else, and the ip6 pings stopped again.
As soon as I disabled the ip6 firewall, my pings returned.
So;
- turning ip6 firewall off immediately returned my ip6 pings.
- turning ip6 firewall on, had no immediate effect (ip6 pings continued)\
- changing something else later, blocked my ip6 pings.
- turning ip6 firewall back OFF, immediately returned my pings.
I'm not sure what exactly I did when the ip6 pings got blocked, but I am assuming that whatever it was caused the ip6 firewall to start blocking local pings again.
Ideally, I would like to keep the ip6 firewall ON, while still being able to ping locally from any ip6 in my /64.
thoughts?
So;
thoughts?
