Problems Accessing SNB via Squid Proxy?
thiggins
Mr. Easy
Staff member
Hi all,
I've had reports of HTTP 500 errors when accessing SmallNetBuilder and SmallCloud builder from people using a Squid proxy.
Anyone else seen this or can run a test to confirm?
Yes, there is a problem.
If running Squid, you just get:
<script type="text/javascript" src="modules/mod_janews/ja.news/ja.news.js"></script>
You have to disable X-Forward ( which seems to confuse SNB ), "If not set, Squid will include your system's IP address or name in the HTTP requests it forwards."
Oddly ( a head scratcher ), if you re-enable X-forward and restart Squid you get an Authentication window, until you disable it again and restart. This leads me to believe that a LAN side address (192.168.x.x) in the X-Forward block is causing the problem.
( I run with HAVP and X Forward disabled, and didn't see the problem until I did a re-install to test )
Thanks, Greg. I figured you'd be the first to respond. :)
I'm aware of the fix. The question is why. X-Forwarded-For is a valid HTTP 1.0 and 1.1 header.
I tried changing to a non private IP. Still have the probem.
Are you running a proxy server up front for SNB? Is it possible that your proxy server is getting confused, seeing a LAN address in the X-Forward, and trying to resolve it?
It appears from this end that the X-Forward-For is getting to you, and trashing the response.
Nope. No proxy in front of the servers as far as I know. At this point it's smelling like an .htaccess config issue.
Problem found and fixed. It was a recently added module that was misbehaving.
