ProFTPD - how to
Yah
Hi All,
I successfully installed and configured ProFTPD on my R7000. The main reason was to make users folder configurable and not to allow ftp users to go below defined user root folder. I assume that Entware already installed and an external USB drive mounded with name USB.
1. Install proftpd server
opkg install proftpd
Configuration file is: /opt/etc/proftp.conf
To start, restart, stop proftp daemon: /opt/etc/init.d/S66proftpd
To debug configuration settings: proftpd -d10
2. Configuration file changes
Commented Anonymous section
Added or changed
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
# Set the user and group under which the server will run.
User                admin
Group                root
# optional to allow admin access
#RootLogin  on
# user authentication files
AuthUserFile      /opt/etc/proftpd/ftpd.passwd id 500-510
AuthGroupFile     /opt/etc/proftpd/ftpd.group
The last two line in the config file allow to authenticate users with id range 500-510 defined in the specified files. You have to create /opt.etc/proftpd folder and make sure only admin user can write in that folder. Otherwise proftpd will generate an error cannot write in world-writable folder.
To create ftpd.passwd and ftp.group files as an easy step you can copy passwd, group, shadow files from /etc folder an rename them. Then using existing templates you can keep just a single group
ftp:x:505:
To create ftp users you may clone existing copied users just replacing "x" with the password from shadow file and adding user root folder or use provided template
Guest:CryptedPasswordIsH:501:505::/mnt/USB/ftproot/Guest:
My template adds user Guest with ID 501 with user root folder/mnt/USB/ftproot/Guest
If you need to add more user you can use 'mkpasswd" utility to generate/change user passwords.
If you need to add access from WAN, you need to add a line in firewall-start script
iptables -I INPUT -p tcp --destination-port 21 -j ACCEPT
and add FTP ports forwarding to 192.168.1.1
Fill free to add more notes as everything is based on my personal experience.
Sorry but R700 isnt supported by RMerlin.
