[Q] Way to create a network that doesn't use VPN?
jsteinm1
I just setup a new rt87u router with Merlin firmware and I am using PIA with it. I want to create a "guest" network or some method that I can not use my VPN at times (for example, Craigslist blocks the IP address of the VPN, so I would like to not use it at times).
I tried to create a Guest network so I could exclude the subnet by policy on the VPN, but it looks like the Router still assigns IPs from the main subnet to the guest network. Is there anyway to accomplish what I'm wanting to do?
I've searched around for this and haven't really been able to figure it out. Can anyone point me in the right direction for creating an easy way to selectively NOT use VPN on demand?
The original selective routing or RPDB techniques both simply create a decision rule that determines if the Client VPN should be used for a particular source.
i.e. if the appropriate 'iptables -t mangle PREROUTING fwmark' chain rule or the RPDB 'ip rule' entry exists (depending on the technique used).
If you have a script on the router (say VPN_select_ON_OFF.sh) that can be invoked with the appropriate arguments, then you need to have method of invoking that script remotely
e.g. from a Windows PC (as has been described in an earlier post) you can use PLINK.EXE or encapsulate the remote SSH/TELNET request in say an Autoit script to be able to retrieve the outcome of the script execution.
(Obviously you could also have a cron entry to schedule the script locally on the router.)
So the script simply adds/deletes the 'decision' rule
I wrote the following script originally to selectively route either a specific device or a group of devices using the iptables 'fwmark' technique but you can see from the comments that it now currently uses the RPDB policy 'ip rules' method.
NOTE: The script should be used as an example, and appears overly complicated but essentially it simply adds/deletes the routing decision rule so is really only 2 commands! :D
EDIT: Hmm perhaps I should have actually replied to this thread ....
http://www.snbforums.com/threads/ho...-from-open-vpn-client-using-batch-file.27678/
#!/bin/sh
# Usage:  VPN_select_ON_OFF {1 | 2 | 3} [host.dnsmasq | ip_address | KEY_tag] {ON | OFF} {FORCE | NOFORCE}
#             where  1 | 2            VPN Client to be used
#                      3              PPTP or L2TP Client to be used
#                    Host.dnsmasq     will be matched against /etc/hosts.dnsmasq contents
#                    Key_tag          will be matched against /mnt/$MYROUTER/VPN_MASKS.txt
#                    ON | OFF         VPN routing (if omitted then the audit file will be used to flip)
#                    FORCE | NOFORCE  Enforce or remove WAN blocking
# e.g.
#        VPN_select_ON_OFF   1  u200-115   on   force
#        VPN_select_ON_OFF   1  u200-115   off  noforce
#        VPN_select_ON_OFF   2  192.168.10.8/29
#        VPN_select_ON_OFF   2  192.168.10.200-192.168.10.203   on   force
#        VPN_select_ON_OFF   1  192.168.10.8/29   force
#        VPN_select_ON_OFF   1  192.168.10.8/29   noforce
#        VPN_select_ON_OFF  1  All_Phones  off
MYROUTER=$(nvram get computer_name)
USEPATH="/tmp/mnt/$MYROUTER"
if [ "$1" != "1" ] && [ "$1" != "2" ] && [ "$1" != "3" ];then
   logger -s -t "($(basename $0))" $$ **ERROR First arg $1 must be 1,2 or 3...... [$@]
   exit 1
else
   if [ "$1" != "3" ];then
      logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for [$@]
   else
      logger -s -t "($(basename $0))" $$ PPTP/L2TP Selective routing for [$@]
   fi
fi
# Translate input args into UPPERCASE
ACTION=`echo $3 | tr '[a-z]' '[A-Z]'`
FORCE=`echo $4 | tr '[a-z]' '[A-Z]'`
# Check if WAN access id to be blocked $3=FORCE requested
if [ "$ACTION" = "FORCE" ];then
   ACTION="NULL"
   FORCE="FORCE"
fi
# Check if WAN access id to be unblocked $3=NOFORCE requested
if [ "$ACTION" = "NOFORCE" ];then
   ACTION="NULL"
   FORCE="NOFORCE"
fi
# Perform a lookup if a hostname (or I/P address) is supplied and is not known to PING
# NOTE: etc/host.dnsmasq is in format
#       I/P address    hostname
if [ "$1" != "" ];then
   IP_NAME=`echo $2 | tr '[a-z]' '[A-Z]'`
   IP_RANGE=`ping -c1 -t1 -w1 $IP_NAME 2>&1 | tr -d '():' | awk '/^PING/{print $3}'`
   if [ -z $IP_RANGE ];then        # Not PINGable so lookup static
      IP_RANGE=`grep -i "$IP_NAME" /etc/hosts.dnsmasq  | awk '{print $1}'`
      logger -s -t "($(basename $0))" $$ "Lookup '$IP_NAME' in DNSMASQ returned:>$IP_RANGE<"
      # If entry not matched in /etc/hosts.dnsmasq see if it exists in our VPN_MASKS.txt lookup file
      #       KEY     I/P address
      if [ "$IP_RANGE" = "" ];then
         IP_RANGE=`grep -i "^$2" $USEPATH/VPN_MASKS.txt | awk '{print $2}'`
         logger -s -t "($(basename $0))" $$ "Lookup '$IP_NAME' in $USEPATH/VPN_MASKS.txt returned:>$IP_RANGE<"
      fi
   fi
else
   #IP_NAME="U200-115"
   IP_NAME="HP-SPECTRE"
   IP_RANGE=`grep -i $IP_NAME /etc/hosts.dnsmasq  | awk '{print $1}'`
   logger -s -t "($(basename $0))" $$ "DEFAULT '$IP_NAME' lookup returned:>$IP_RANGE<"
fi
echo "Processing options: $IP_NAME - $ACTION - $FORCE"
# Validate the I/P address
REGEX="\b(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\b"
CHECK=$(echo $IP_RANGE | egrep $REGEX)
if [[ "$?" -eq 0 ]];then
   echo "Valid IP address " $IP_RANGE
else
   logger -s -t "($(basename $0))" $$ **ERROR Invalid IP address $IP_RANGE
   exit 1
fi
   logger -s -t "($(basename $0))" $$ "**ERROR Missing arg: DNSMASQ hostname or IP address"
   exit 1
fi
# Is the actual VPN client UP....well is there a route to the VPN?
VPNROUTE=`ip route show | grep -a "dev tun1"$1`
if [ "x$VPNROUTE" = "x" ];then
   logger -s -t "($(basename $0))" $$ "**Warning VPN Client$1 is not UP?"
   #exit 1
fi
# Flip the VPN selective routing if the tracking file exists and no explicit directive supplied
if [ -e $USEPATH/VPN_$IP_RANGE.txt ] && [ "$ACTION" = "" ] ;then
   # Retrieve the previous known status (Reboot should definitely delete these files?  - see post-mount or ip_down event?)
   ON_OFF=`cat $USEPATH/VPN_$IP_RANGE.txt`
   if [ "$ON_OFF" = `grep -i "VPN"$1 /jffs/configs/VPNSelect  | awk '{print $3}'` ];then
      ACTION="OFF"
      logger -s -t "($(basename $0))" $$ "Current '$IP_NAME' tracking file is MARK=$ON_OFF (ON)"
   else
      ACTION="ON"
      logger -s -t "($(basename $0))" $$ "Current '$IP_NAME' tracking file is MARK=$ON_OFF (OFF)"
   fi
fi
MY_VPNTAB=`grep -i "VPN$1" /jffs/configs/VPNSelect  | awk '{print $2}'`
# Turn selective routing OFF
if [ "$ACTION" = "OFF" ];then
   ON_OFF=0
   #logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE set MARK=$ON_OFF "(OFF)"
   logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE RPDB $MY_VPNTAB "(OFF)"
   # Remove the selective rerouting....why ADD a new line with the mark set OFF?
   #iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range $IP_RANGE -j MARK --set-mark $ON_OFF
   # .... why not simply delete the entire entry..but have to try all MARK entries!!!!
   #iptables -t mangle -D PREROUTING -i br0 -m iprange --src-range $IP_RANGE -j MARK --set-mark 1 2> /dev/null > /dev/null
   #iptables -t mangle -D PREROUTING -i br0 -m iprange --src-range $IP_RANGE -j MARK --set-mark 2
   ip rule del from $IP_RANGE lookup $MY_VPNTAB 2> /dev/null > /dev/null
fi
# Turn selective routing ON
if [ "$ACTION" = "ON" ];then
   #ON_OFF=2
   ON_OFF=`grep -i "VPN"$1 /jffs/configs/VPNSelect  | awk '{print $3}'`
   #logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE set MARK=$ON_OFF "(ON)"
   # Enable the selective rerouting
   # Prevent duplicate selective routing rule entries
   # If the $IP_RANGE is xxx.xxx.xxx.xxx-xxx.xxx.xxx.xxx or xxx.xxx.xxx.xxx,xxx.xxx.xxx.xxx then use -t mangle syntax
   #iptables -t mangle -D PREROUTING -i br0 -m iprange --src-range $IP_RANGE -j MARK --set-mark $ON_OFF 2> /dev/null > /dev/null
   # Example for routing a specific port via VPN
   # iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range $IP_RANGE -p tcp --dport ppppp -j MARK --set-mark $ON_OFF
      #Apr 2015: Policy routing is more reliable for devices and or a subnet mask;
   #  i.e if the -t mangle table gets flushed by the DPI engine? then selective routing via ip rule will STILL work!
   #      iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range xxx.xxx.xxx.xxx -j MARK --set-mark $TAG_MARK
   #      or
   logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE RPDB $MY_VPNTAB "(ON)"
   ip rule add from $IP_RANGE lookup $MY_VPNTAB
   #      The two statements above are the same... and we can route ALL devices via the VPN...
   #      iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range xxx.xxx.xxx.0/24 -j MARK --set-mark $TAG_MARK
   #      or
   #      ip rule add from xxx.xxx.xxx.0/24 lookup $MY_VPNTAB
fi
# Optionally FORCE the use of the VPN tunnel, so if the VPN tunnel drops, the device will not use the unencrypted default WAN
if [ "$FORCE" = "FORCE" ];then
   logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE WAN access blocked
   # Prevent duplicate blocking rule entries
   iptables -D FORWARD -i br0 -s $IP_RANGE -o eth0 -j DROP 2> /dev/null > /dev/null
   iptables -I FORWARD -i br0 -s $IP_RANGE -o eth0 -j DROP
   #ip route add unreachable default table $VPN_TBL
fi
# Allow removing of the WAN blocking if it was previously set
if [ "$FORCE" = "NOFORCE" ];then
   logger -s -t "($(basename $0))" $$ VPN$1 Selective routing for $IP_RANGE WAN access allowed
   #ip route del unreachable default table $VPN_TBL
fi
# Track known status of VPN selective routing.....
echo $ON_OFF > $USEPATH/VPN_$IP_RANGE.txt
# Debug the routing tables
/jffs/scripts/IPTablesDump.sh "VPN$1_Client_$IP_RANGE-$ACTION"
exit 0
Wow that seems complicated for this haha! Thank you for taking the time to respond, I will have to read though this and see if I can do it.
My other thought was to set a specific IP address and use a policy to not VPN that source IP, then just manually set my IP when I want to shut VPN off on that particular computer/device.
To access Craigslist from behind a blocked IP, try Google this:
free web proxy list
These HTTP proxy websites are only good for entering a URL and viewing the web page.
Some work and some don't. Eventually, you will find one that works. AND, eventually each one will get discovered and blocked, but more new ones always keep coming. It is how my friend access Craigslist from behind the TOR network.
I was once looking for the same setup as you. It sure would be nice to have an option in the GUI to setup a DHCP scope for the Guest network, because this would make the policy vpn routing much easier. In the end I brought a cheap refurb router ($15) that acts as my vpn network and I use the dhcp scope on this router for that ssid. I then have a route back to my 87u router to use the vpn only on that ssid.
Not ideal but it works.
Indeed that is a solution, in fact for wireless devices, you could set up one of the Guest WiFi SSIDs to always use the VPN then simply disconnect/connect to the appropriate SSID....without any complex scripts! :p
Can you elaborate? That was my original question, to just have another SSID that does not use the VPN that I can connect to, but I can't see how to set that up.
So the Wiki example SSID VPN https://github.com/RMerl/asuswrt-me...or-VPN-and-SSID-for-Regular-ISP-using-OpenVPN. either doesn't work for you or doesn't meet your needs?
By default all SSIDs bypass VPNs so if you configure one Guest SSID to always use the VPN then you simply connect to it...in which case the Wiki example should meet your needs.
Anyway I apparently posted my custom version of the original script back in February 2015, and hopefully may still be valid... http://pastebin.com/kW4RxK78 so you should be able deduce how the script works.
So the Wiki example SSID VPN link that was posted earlier either doesn't work for you or doesn't meet your needs?
Whoops maybe it does. I went down the path of just looking for VLAN info in the wiki by the first reply, which I didn't find what I was looking for. But now I see the specific how-to's. I'll look though those and your link...which should take care of it. Thanks for getting me straightened out!
