microchip
Thanks again for all your help.
I'm just curious as to what would happen with the guest network and the AP. I wonder if I can set the AP to only use the main network br0?
Your AP is hooked up to the R7000. This means it'll get its IP address from your LAN (br0) network. Your Guest network (br1) is separate and isolated. If you want to use the AP to provide Guest access, you need to check one of the LAN ports in the VLAN setting. This port will be used for the AP to provide Guest access
