shelleyevans
Router: RT-AC86U
Access Point: RT-AC68U
Wifi Repeater: RT-AC66U_B1
I'm playing with Roaming Assistant. I noticed that I can adjust the transmission power on the access point, and reduced the power to help with overlapping signals. I also enabled Roaming Assistant on the access point (as well as the router) and set a higher disconnect [-65 dBm] at the AP than at the router, to encourage clients to stay with the router.
Everything seems okay, but I got these messages in my wifi log, and wondered if they are related.
Thank you!
Thank you!
