route external wild card domain to internal proxy
waeking
I do not want to open up port 80 and forward to traefik running on an internal pc unless the specific domain is used. For example if I go to the External Static IP (http://123.456.123.456:80) I dont want anything to happen. However if I go to fresh.pxy.domain,com I would like that to go to the actual traefik proxy. I know how to setup the dns wildcard A record (*.pxy.domain.com). That has been done.
I can't seem to find any documentation on this as of yet. I am not sure what I should even be searching for.
Any assistance would be great!
 iptables -t nat -A PREROUTING -d *.pxy.domain.com -i eth0 -p tcp -m tcp -j DNAT --to-destination 192.168.1.100
would something like this work?
No, because iptables translates a domain name into an IP address when the command is issued. It also doesn't accept wildcards.
Would some sort of reverse proxy built into the router (wan facing) be able to do this? or would two reverse proxies (router and traefik) be able to communicate with each other?
I would have thought it would make sense to do this on the web server as that is able to examine the URL of the incoming requests. I guess you could do it on a reverse proxy as well. Beyond that I don't know. It's not really my area of knowledge.
