RT-AC66U disconnecting alot
atrecks
Hello,
For the last 3-4 Frimwares upgrades I've made, my router has be disconnecting frequently. I couldn't come up with any solution and I am hoping I can find it here.
Here's a recent log.
Jan 1 04:00:13 kernel: Initializing USB Mass Storage driver...
Jan 1 04:00:13 kernel: usbcore: registered new interface driver usb-storage
Jan 1 04:00:13 kernel: USB Mass Storage support registered.
Jan 1 04:00:13 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0214000
Jan 1 04:00:13 kernel: NTFS (with native replay) support included
Jan 1 04:00:13 kernel: optimized: speed
Jan 1 04:00:13 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 04:00:13 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 04:00:13 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan 1 04:00:13 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Jan 1 04:00:13 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Jan 1 04:00:13 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Jan 1 04:00:13 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan 1 04:00:13 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 04:00:13 kernel: hub 1-0:1.0: USB hub found
Jan 1 04:00:13 kernel: hub 1-0:1.0: 2 ports detected
Jan 1 04:00:13 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 04:00:13 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Jan 1 04:00:13 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Jan 1 04:00:13 kernel: ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
Jan 1 04:00:13 kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 04:00:13 kernel: hub 2-0:1.0: USB hub found
Jan 1 04:00:13 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 04:00:13 kernel: usbcore: registered new interface driver usblp
Jan 1 04:00:13 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Jan 1 04:00:13 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
Jan 1 04:00:13 kernel: usb 1-1: configuration #1 chosen from 1 choice
Jan 1 04:00:13 kernel: hub 1-1:1.0: USB hub found
Jan 1 04:00:13 kernel: hub 1-1:1.0: 4 ports detected
Jan 1 04:00:13 kernel: usbcore: registered new interface driver asix
Jan 1 04:00:13 kernel: usbcore: registered new interface driver cdc_ether
Jan 1 04:00:13 kernel: usbcore: registered new interface driver rndis_host
Jan 1 04:00:13 kernel: cdc_ncm: 04-Aug-2011
Jan 1 04:00:13 kernel: usbcore: registered new interface driver cdc_ncm
Jan 1 04:00:13 syslog: module cdc_wdm not found in modules.dep
Jan 1 04:00:13 syslog: module qmi_wwan not found in modules.dep
Jan 1 04:00:13 syslog: module cdc_mbim not found in modules.dep
Jan 1 04:00:14 kernel: br0: starting userspace STP failed, staring kernel STP
Jan 1 04:00:14 kernel: vlan1: dev_set_promiscuity(master, 1)
Jan 1 04:00:14 kernel: device eth0 entered promiscuous mode
Jan 1 04:00:14 kernel: device vlan1 entered promiscuous mode
Jan 1 04:00:14 kernel: device eth1 entered promiscuous mode
Jan 1 04:00:14 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Jan 1 04:00:14 kernel: device eth2 entered promiscuous mode
Jan 1 04:00:14 kernel: br0: port 3(eth2) entering listening state
Jan 1 04:00:14 kernel: br0: port 2(eth1) entering listening state
Jan 1 04:00:14 kernel: br0: port 1(vlan1) entering listening state
Jan 1 04:00:14 kernel: br0: port 3(eth2) entering learning state
Jan 1 04:00:14 kernel: br0: port 2(eth1) entering learning state
Jan 1 04:00:14 kernel: br0: port 1(vlan1) entering learning state
Jan 1 04:00:14 kernel: br0: topology change detected, propagating
Jan 1 04:00:14 kernel: br0: port 3(eth2) entering forwarding state
Jan 1 04:00:14 stop_nat_rules: apply the redirect_rules!
Jan 1 04:00:14 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 04:00:14 kernel: br0: port 1(vlan1) entering forwarding state
Jan 1 04:00:14 WAN Connection: Fail to connect with some issues.
Jan 1 04:00:15 dnsmasq[304]: started, version 2.69rc4 cachesize 1500
Jan 1 04:00:15 dnsmasq[304]: asynchronous logging enabled, queue limit is 5 messages
Jan 1 04:00:15 dnsmasq-dhcp[304]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 1 04:00:15 dnsmasq-dhcp[304]: DHCP, sockets bound exclusively to interface br0
Jan 1 04:00:15 dnsmasq[304]: read /etc/hosts - 5 addresses
Jan 1 04:00:15 RT-AC66U: start httpd
Jan 1 04:00:15 syslog: Generating SSL certificate...
Jan 1 04:00:18 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.167 ac:22:0b:26:22:a7
Jan 1 04:00:18 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.167 ac:22:0b:26:22:a7 User
Jan 1 04:00:20 syslog: SNet version started
Jan 1 04:00:20 miniupnpd[342]: HTTP listening on port 57434
Jan 1 04:00:20 miniupnpd[342]: Listening for NAT-PMP traffic on port 5351
Jan 1 04:00:20 disk monitor: be idle
Jan 1 04:00:20 miniupnpd[342]: Failed to get ip address for interface
Jan 1 04:00:30 pppd[345]: Plugin rp-pppoe.so loaded.
Jan 1 04:00:30 pppd[345]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
Jan 1 04:00:30 pppd[346]: pppd 2.4.5 started by admin, uid 0
Jan 1 04:00:30 pppd[346]: PPP session is 18249 (0x4749)
Jan 1 04:00:30 pppd[346]: Connected to 00:00:5e:00:01:01 via interface eth0
Jan 1 04:00:30 pppd[346]: Using interface ppp0
Jan 1 04:00:30 pppd[346]: Connect: ppp0 <--> eth0
Jan 1 04:00:31 pppd[346]: PAP authentication succeeded
Jan 1 04:00:31 pppd[346]: peer from calling number 00:00:5E:00:01:01 authorized
Jan 1 04:00:31 pppd[346]: local IP address 92.98.102.107
Jan 1 04:00:31 pppd[346]: remote IP address 213.42.8.34
Jan 1 04:00:31 pppd[346]: primary DNS address 213.42.20.20
Jan 1 04:00:31 pppd[346]: secondary DNS address 195.229.241.222
Jan 1 04:00:31 dnsmasq[304]: read /etc/hosts - 5 addresses
Jan 1 04:00:31 dnsmasq[304]: using nameserver 213.42.20.20#53
Jan 1 04:00:31 dnsmasq[304]: using nameserver 195.229.241.222#53
Jan 1 04:00:31 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jan 1 04:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 04:00:32 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 04:00:32 rc_service: ip-up 363:notify_rc stop_upnp
Jan 1 04:00:32 miniupnpd[342]: received signal 15, good-bye
Jan 1 04:00:32 rc_service: ip-up 363:notify_rc start_upnp
Jan 1 04:00:32 syslog: SNet version started
Jan 1 04:00:32 rc_service: ip-up 363:notify_rc stop_ntpc
Jan 1 04:00:32 rc_service: ip-up 363:notify_rc start_ntpc
Jan 1 04:00:33 miniupnpd[412]: HTTP listening on port 46869
Jan 1 04:00:33 miniupnpd[412]: Listening for NAT-PMP traffic on port 5351
Jan 1 04:00:34 WAN Connection: WAN was restored.
Jan 1 04:00:36 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.35 28:6a:ba:e4:dd:92
Jan 1 04:00:36 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.35 28:6a:ba:e4:dd:92 Sultans-iPad
Jan 1 04:00:36 kernel: eth1: received packet with own address as source address
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPDISCOVER(br0) c8:d7:19:8c:10:d5
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPOFFER(br0) 192.168.1.117 c8:d7:19:8c:10:d5
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.108 ca:d7:19:b4:ac:bd
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.108 ca:d7:19:b4:ac:bd BinToaqsiPad2
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.117 c8:d7:19:8c:10:d5
Jan 1 04:00:38 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.117 c8:d7:19:8c:10:d5 RE1000
Jan 1 04:00:39 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.35 28:6a:ba:e4:dd:92
Jan 1 04:00:39 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.35 28:6a:ba:e4:dd:92 Sultans-iPad
Jan 1 04:00:44 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.108 ca:d7:19:b4:ac:bd
Jan 1 04:00:44 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.108 ca:d7:19:b4:ac:bd BinToaqsiPad2
Jan 1 04:00:51 dnsmasq-dhcp[304]: DHCPREQUEST(br0) 192.168.1.225 88:30:8a:41:8c:d5
Jan 1 04:00:51 dnsmasq-dhcp[304]: DHCPACK(br0) 192.168.1.225 88:30:8a:41:8c:d5 android-895162d1ed7d680e
May 27 15:57:58 rc_service: ntp 414:notify_rc restart_upnp
May 27 15:57:58 rc_service: ntp 414:notify_rc restart_diskmon
May 27 15:57:58 rc_service: waitting "restart_upnp" via ntp ...
May 27 15:57:58 miniupnpd[412]: received signal 15, good-bye
May 27 15:57:58 syslog: SNet version started
May 27 15:57:58 miniupnpd[424]: HTTP listening on port 58193
May 27 15:57:58 miniupnpd[424]: Listening for NAT-PMP traffic on port 5351
May 27 15:57:59 disk monitor: be idle
May 27 15:58:02 pppd[346]: System time change detected.
Don't mind the date, for some reason it is showing Jan 1st right before May 27th.
