Dismiss Notice
Welcome To SNBForums
RT-AC66u Wireless issues
Discussion in 'ASUS AC Routers & Adapters' started by BossertGF, Jan 12, 2013.
  1. BossertGF
    BossertGF New Around Here
    Jan 12, 2013
    4
    Hi all trust you are well?
    Im having a real absured experience with this router.
    It works great for most things except, Splashtop Remote desktop is jittery and laggin.
    Doesint matter what channels I change it remains the same.
  2. mikeg
    mikeg Senior Member
    Sep 8, 2012
    326
    Sweden
    What firmware do you have ?
    Is it the 2.4 or 5 Ghz band you have trounle with ?
  3. BossertGF
    Jan 12, 2013
    4
    HI. yes its on both bands.
    I have also tried both the latest official and Merlins build of the firmware.
    Same Results.
  4. kayphoonstar
    kayphoonstar Occasional Visitor
    May 5, 2010
    25
    Oregon
    Is WMM enabled?
  5. BossertGF
    Jan 12, 2013
    4
    Hi, yes WMM is enabled.
  6. mikeg
    mikeg Senior Member
    Sep 8, 2012
    326
    Sweden
    What Channel width have you set on each band ?
  7. TonyH
    TonyH Very Senior Member
    Feb 19, 2012
    1,390
    Calgary AB Canada
    What is the WiFi card in the desktop? Latest driver are you using for it?
  8. BossertGF
    Jan 12, 2013
    4
    hi I have tried putting it on 20/40mhz and 80 setting same result. my PC is connected through a Wired connection.
Share This Page
