Hi all,
with the different firmware, often i have problem with dual wan. With some firmware failback doesn't work, with other firmware router skips the primary connection and it connects directly with the backup wan.
My settings is PRIMARY WAN: adsl (bridge router) and SECONDARY WAN (Backup): huawei e3372 lte.
I have tested all firmware, the best is 3.0.0.4.380_1354 (stock firmware asus), but now i'm testing Nerlin 380.60_beta2 and it seems to work.
I'm testing also a script that check with ping the connection and if the "ppp0" is found means that adsl is ready, if not adsl is down.
Generically i fix:
- the failback bug with a interface eth3 down
- the adsl in stand by (router show me primary wan with "connected" but i cannot reach anything via ping ) with a interface eth0 down and up
- if above commends doen't work i use service restart_wan
This is the script, executed every 5 minutes with cron. When i plug and unplug line cable of the modem to force to change to backup wan the router reboots. Why? Anyone can help me to optimize the script?
Generically i fix:
#!/bin/sh
if ! ping -w 10 -c 10 www.google.it > /dev/null && ! "`ifconfig | grep ppp0`" = "" ; then
ifconfig eth3 down
ifconfig eth0 down
sleep 10
ifconfig eth0 up
if ! ping -w 10 -c 10 www.google.it > /dev/null; then
service restart_wan
reboot
fi
fi
fi
else
if ! ping -w 10 -c 10 www.google.it > /dev/null && "`ifconfig | grep ppp0`" = "" ; then
ifconfig eth0 down
fi
fi
