Solved RT-AX58U flashing Merlin failed
FlyByWire
Hi there,
I bought a new Asus RT-AX 58U (here). Trying to flash the Merlin fw (RT-AX58U_3004_388.7_0_puresqubi.w) failed. I already read, that the V2 of the router is not supported, but I think I bought V1 ?!
Any hints?
thanks!
Found this in the description:
RT-AX58U V2 AX3000 AiMesh
so it's V2.
Hi there,
Any hints?
thanks!
so it's V2.
The info is on the label, on the unit. You don't need an Amazon description.
So, a non starter.
Run stock, your only option.
This V2 router is supported by GNUton.
