Hello All,
I just moved into a house that has an aggregation point for all cat5e and coax in an On-Q panel located in a closet. All cat5e looks to be terminated per T568A with RJ45s into a Legrand TM1478 4x12 Telecom Module (see picture). There is a power outlet in the panel as well.
Basically, I'd like to take my cable modem and router and install them in the closet as the starting point for a data network. Can I simply unplug the 4 cables (my router can support 4 ethernet connections) from the TM1478 module which I'd like to use for data and plug them in the router? Any other suggestions are greatly appreciated! (I'm experienced enough at setting up routers and such but the wiring part of this is new)...
