Help NOOB read system log RT-AC 86U mesh
Brunotoo
Hi everyone, NOOB here, thank you for any help ,
should the following from my system log be of any concern?
Jan 22 12:14:00 kernel: pgd = ffffffc011e54000
Jan 22 12:14:00 kernel: [00000000] *pgd=0000000011e61003, *pud=0000000011e61003, *pmd=000000000af33003, *pte=0000000000000000
Jan 22 12:42:23 kernel: pgd = ffffffc0151e8000
Jan 22 12:42:23 kernel: [00000000] *pgd=0000000011a49003, *pud=0000000011a49003, *pmd=00000000151ce003, *pte=0000000000000000
Jan 22 12:50:11 kernel: pgd = ffffffc011b12000
Jan 22 12:50:11 kernel: [00000000] *pgd=0000000011911003, *pud=0000000011911003, *pmd=000000001191d003, *pte=0000000000000000
Jan 22 13:01:05 kernel: pgd = ffffffc011aab000
Jan 22 13:01:05 kernel: [00000000] *pgd=00000000118d8003, *pud=00000000118d8003, *pmd=00000000170da003, *pte=0000000000000000
Jan 22 13:27:56 kernel: pgd = ffffffc014093000
Jan 22 13:27:56 kernel: [00000000] *pgd=00000000119ef003, *pud=00000000119ef003, *pmd=0000000011a52003, *pte=0000000000000000
Jan 22 13:41:48 kernel: pgd = ffffffc019158000
Jan 22 13:41:48 kernel: [00000000] *pgd=00000000151ce003, *pud=00000000151ce003, *pmd=0000000011abf003, *pte=0000000000000000
Jan 22 14:12:08 kernel: pgd = ffffffc01190c000
Jan 22 14:12:08 kernel: [00000000] *pgd=000000001198f003, *pud=000000001198f003, *pmd=0000000011f83003, *pte=0000000000000000
Jan 22 14:35:00 kernel: pgd = ffffffc0150a4000
Jan 22 14:35:00 kernel: [00000000] *pgd=00000000191c3003, *pud=00000000191c3003, *pmd=0000000012a21003, *pte=0000000000000000
Jan 22 14:48:16 kernel: pgd = ffffffc011a55000
Jan 22 14:48:16 kernel: [00000000] *pgd=0000000011b6b003, *pud=0000000011b6b003, *pmd=0000000015261003, *pte=0000000000000000
Jan 22 15:02:35 kernel: pgd = ffffffc011b9e000
Jan 22 15:02:35 kernel: [00000000] *pgd=000000000af33003, *pud=000000000af33003, *pmd=0000000015186003, *pte=0000000000000000
Jan 22 15:12:18 kernel: pgd = ffffffc011bfd000
Jan 22 15:12:18 kernel: [00000000] *pgd=000000001190c003, *pud=000000001190c003, *pmd=00000000152b8003, *pte=0000000000000000
Jan 22 15:31:06 kernel: pgd = ffffffc01190c000
Jan 22 15:31:06 kernel: [00000000] *pgd=0000000012a88003, *pud=0000000012a88003, *pmd=000000000b739003, *pte=0000000000000000
Jan 22 15:49:36 kernel: pgd = ffffffc01518c000
Jan 22 15:49:36 kernel: [00000000] *pgd=0000000011fcc003, *pud=0000000011fcc003, *pmd=0000000011ae8003, *pte=0000000000000000
Jan 22 16:12:06 kernel: pgd = ffffffc0118a1000
Jan 22 16:12:06 kernel: [00000000] *pgd=0000000011a56003, *pud=0000000011a56003, *pmd=000000001517b003, *pte=0000000000000000
Jan 22 16:15:16 kernel: pgd = ffffffc019122000
Jan 22 16:15:16 kernel: [00000000] *pgd=00000000118a8003, *pud=00000000118a8003, *pmd=0000000012174003, *pte=0000000000000000
Jan 22 16:34:33 kernel: pgd = ffffffc0170fd000
Jan 22 16:34:33 kernel: [00000000] *pgd=00000000193ab003, *pud=00000000193ab003, *pmd=000000001518c003, *pte=0000000000000000
Jan 22 16:52:46 kernel: pgd = ffffffc0118be000
Jan 22 16:52:46 kernel: [00000000] *pgd=0000000011ba9003, *pud=0000000011ba9003, *pmd=00000000170f2003, *pte=0000000000000000
Jan 22 17:08:03 kernel: pgd = ffffffc0119a9000
Jan 22 17:08:03 kernel: [00000000] *pgd=0000000011994003, *pud=0000000011994003, *pmd=0000000011b4d003, *pte=0000000000000000
Jan 22 17:35:41 kernel: pgd = ffffffc011936000
Jan 22 17:35:41 kernel: [00000000] *pgd=0000000011a24003, *pud=0000000011a24003, *pmd=0000000011861003, *pte=0000000000000000
Jan 22 17:52:02 kernel: pgd = ffffffc011f83000
Jan 22 17:52:02 kernel: [00000000] *pgd=000000001914c003, *pud=000000001914c003, *pmd=0000000011936003, *pte=0000000000000000
Jan 22 17:55:26 kernel: pgd = ffffffc0157f5000
Jan 22 17:55:26 kernel: [00000000] *pgd=00000000118c4003, *pud=00000000118c4003, *pmd=0000000012ae7003, *pte=0000000000000000
I am running mesh rt-ac86u and rt-ac68u, latest firmware,AiProtection turned off and the following:
List of installed Entware packages (28)
column - 2.34-1 libpcre - 8.43-1
coreutils - 8.30-2 libpthread - 2.27-8
coreutils-chroot - 8.30-2 librt - 2.27-8
entware-opt - 227000-3 libsmartcols - 2.34-1
entware-release - 1.0-2 libssp - 7.4.0-8
entware-upgrade - 1.0-1 libstdcpp - 7.4.0-8
file - 5.37-1 locales - 2.27-8
findutils - 4.6.0-4 nano - 4.4-2
grep - 3.3-1 opkg - 2019-06-14-dcbc142e-1
libc - 2.27-8 pixelserv-tls - 2.2.1-1
libgcc - 7.4.0-8 terminfo - 6.1-5
libmagic - 5.37-1 zlib - 1.2.11-3
libncursesw - 6.1-5 zoneinfo-asia - 2019c-1
libopenssl - 1.1.1d-1 zoneinfo-europe - 2019c-1
Entware Apps installed in /opt/bin/ (16)
ash diversion islebe netstat
chroot file locale.new pixelserv-tls
column find localedef.new sh
debian grep nano xargs
Non-Entware Scripts installed in /opt/bin/ (2)
amtm diversion
Entware Apps installed in /opt/sbin/ (2)
ifconfig route
quote
https://www.snbforums.com/threads/rt-ac86u-possible-kernel-crash.54221/
Actually, the best way to disble the Trend Micro stuff is Administration\Privacy\Withdraw. quote
I have done the above as per link some 25 minutes ago and none of the original stuff came up when I rebooted the router via gui
But this came up:
May 5 15:05:10 kernel: nand: Could not find valid ONFI parameter page; aborting
May 5 15:05:10 kernel: brcmboard registered
May 5 15:05:10 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May 5 15:05:10 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 15:05:10 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 15:05:10 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 15:05:10 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 15:05:10 kernel: broadcomThermalDrv brcm-therm: init (CPU count 2 2 2 2)
May 5 15:05:10 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link UP 1000 mbps full duplex
May 5 15:05:10 kernel: hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
May 5 15:05:13 avahi-daemon[965]: Alias name RT-AC86U: avahi_server_add_cname failure: The requested operation is invalid because redundant
May 5 15:05:18 modprobe: module scsi_wait_scan not found in modules.dep
May 5 15:05:18 modprobe: module uas not found in modules.dep
May 5 15:05:18 modprobe: module mbcache not found in modules.dep
May 5 15:05:18 modprobe: module jbd not found in modules.dep
May 5 15:05:18 modprobe: module ext3 not found in modules.dep
May 5 15:05:18 modprobe: module ext4 not found in modules.dep
May 5 15:05:18 modprobe: module ext2 not found in modules.dep
May 5 15:05:18 modprobe: module btusbdrv not found in modules.dep
May 5 15:05:19 kernel: sd 0:0:0:0: [sda] No Caching mode page found
May 5 15:05:19 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan 22 19:09:12 pixelserv-tls[1475]: pixelserv-tls 2.2.1 (compiled: May 22 2019 13:44:50 flags: tfo tls1_3) options: 192.168.1.2
Jan 22 19:09:12 pixelserv-tls[1475]: Listening on :192.168.1.2:443
Jan 22 19:09:12 pixelserv-tls[1475]: Listening on :192.168.1.2:80
Jan 22 19:09:15 avahi-daemon[965]: Alias name RT-AC86U: avahi_server_add_cname failure: The requested operation is invalid because redundant
Jan 22 19:09:16 avahi-daemon[1854]: Alias name RT-AC86U: avahi_server_add_cname failure: The requested operation is invalid because redundant
Jan 22 19:09:49 crond[958]: time disparity of 903124 minutes detected
