[SOLVED] How to access NVRAM?
pesche
Hello,
I planing to reset my AC68U.
In the NVRAM FAQ there is a nice tutorial. Also how to perform a text based backup.
My problem is.
I can't run 'nvram'. The command is not found.
Did I missed something? Do I have to install it?
thanks!
AFAIK the nvram command is part of the basic firmware, so unless you've messed up your search path...
Try this:
/usr/sbin/nvram
For anyone on an AC66U, use /bin/nvram instead
You can find out where your router's nvram command is by running 'which nvram' (sans quotes) from an SSH console session.
EDIT: Sorry for grave digging.. I was having a similar issue and stumbled upon this thread without checking the date.
