[SOLVED] Terminating cable to keystone and other end to RJ45
kamaran
I'm trying to run a cat6 from a wall panel keystone on one (X) side and an RJ45 (Y) on the other to connect to an IP camera.
All connected correctly via the 568-B Wiring wiring method, however when I test with a LAN cable tester nothing is working??
Into the testing tool I'm connecting the RJ45 (Y) and another cable connected to (X).
Help PLEASE?!!!
Problem solved, I had wired the RJ45 connector right to left instead of left to right :)
Quick Point of reference.
568B is the following order (left to right, tab down)
White Orange
Orange
White Green
Blue
White Blue
Green
White Brown
Brown
TIA568A is swapping white orange for white green and orange for green
