Hi all.
I have a 500mbps fiber installed in my house and I'm using an Asus rt-n66u router (firmware version 3.0.0.4.276, because the last one from Asus website, 3.0.0.4.374.979, was really bad for wifi signal).
The maximum I can see from this router is 170mbps when I'm connected on my Intel gigabit network card. I also tested 2 more gigabit cards and the result was the same.. 170mbps.
I also disabled firewall, disabled Qos, disabled HW acceleration, disabled wifi, enabled Jumbo.. still 170-180mbps.
Using direct connection without the router I can get 450mbps and this seems right for a 500mbps connection.
Is there any settings that I'm missing for n66u to make it work at full speed on gigabit ?
Any other suggestion?
