WARNING: I'm noob on this and doing it on my own so be careful and DIY at your own risk! Or better wait while I try to complete the adapters before you burn your NAS...
Hello, after some years of hard duty my Synology make some irritating noise. As you can find in Synology's forums is caused by the PSU fan. Due warranty is now finished I decided to exchange the original PSU (300W) to a fanless low power PSU (150W). A review shows 103W as maximum W so the 80% 150W (~120W) must be enought for 8x3TB discs.
Being a noob in electrical issues I want to share and ask for help to complete this operation. Let's do it!
Original Synology PSU Data:
PSU 250W_1
Description: PSU 250W 24p+8p+6p
Connectors: ATX, 12 pin molex, 8 pin molex
EAN: 4711174729210
UPC: 846504009213
Dimensions: 15.5 x8.1 x4.1 cm
Weight: 0.82 kg
Models: DS1010+, DS1511+, DS1512+, DS1812+, DX510, DX513, RS409, RS411, RS810+, RS812, RS812+, RX410
Detailed PSU specs
150W Fanless PSU replacing unit:
type: Fortron Source FSP150-50TNF Flex ATX v2.0 power supply
performance: 150 Watt
ventilation: completely fanless construction
connectors:
- 1 x 20+4-pol. mainboard-connector (ATX)
- 1 x 4-pol. 12V / P4-connector
- 2 x SATA- connector
- 1 x 4-pol. Molex- connector + 1 x 4-pol. Molex Floppy- connector
Output: - +3,3V / 14A
- +5Vsb / 2.0A
- +12V combined / 14A
- -12V / 0.5A
dimensions: (W x D x H) : 150mm x 81,5mm x 40,3mm
additional: - suitable for use in very narrow 19" server enclosures with a height of 1U or certain mini ITX enclosures
- active PFC
- Over voltage protection
Detailed PSU specs
Starting the PSU's connector adapters...
Synology PSU connectors & adapters schemes. ATENTION: This schemes are from male molex to male molex (obviously the female molex in the new cable is mirrored)
Normal ATX connector. All PSU will have this connector (ATX 20 pin + 4 pin) so no adapter is needed.
Own Synology molex connectors (12 pin molex and 8 pin molex):
Synology Connectors Color scheme (R - Red 5v, N - Black Ground, A - Yellow 12v1, AN - Yellow/Black 12v2) both molex front view :
Normal PSU connectors (4pin molex & SATA) have to be adapted to synolgy own molex. As long as my PSU don't have the 12v1 & 12v2 (only 12v) the adapter from molex to synology connectors will be:
My fanless PSU have only ATX, 2xsata and 1x4pin molex so I have to split the 4 pin molex in two 4 pin molex or adapt SATA to 4 pin molex and then create my own adapted connectors.
In the molex+SATA scheme we can keep the Watts splited on both PSU cables (4pin molex & SATA) to no overcharge one single molex connector.
Will continue....comments are welcome.
References, sources and others...
- I'm using a fantastic guide to make your own wires from here
PSU 250W_1
EAN: 4711174729210
UPC: 846504009213
Weight: 0.82 kg
Detailed PSU specs
connectors:
- +5Vsb / 2.0A
- -12V / 0.5A
- active PFC
Detailed PSU specs
