Synology DS411+II or Qnap TS-459 Pro+
Which would you go for and why?
http://www.smallnetbuilder.com/nas/nas-reviews/31358-new-to-the-charts-qnap-ts-459-pro-reviewed
Short answer is that both are very good and neither is dramatically better than the other. Same processors, ram, # of bays. Both perform very well.
Synology is generally considered to have the better user interface. It lacks hotswap drive bays of the Qnap. It's quieter though.
Basically it doesn't make a huge difference. If the NAS is going somewhere you might hear it, the 411 is probably better. But I would probably make my decision on how much you like the user interface and add-on software you can run (if you even care about that).
Demos for the UIs
http://www.synology.com/dsm/index.php?lang=us
http://www.qnap.com/USEng/liveDemo.asp
Many thanks, you've actually just answered a question I've raised in another thread regarding the interfaces. :)
