Sysem Commands
keef
Hello. I use Merlin 384.13. Is there a way to enter a system command? I understand Merlin is not WRT however to clarify what I am talking about on WRT is is Administration > Commands. I'd like to install a VPN applet.
thanks
thanks
No that's been removed from the WebUI for security reasons a long time ago.
Enable SSH in Administration/System for "LAN only" and use an SSH client to log in with your router credentials.
Thanks for the help, I appreciate it. I was not sure using an SSH login was entirely the same thing.
Keef
Keef
It does the same thing, trough a secure connection. Be careful though what you enter ;)
