TCP listening sockets according to netstat
David Arnstein
I have a RT-AC68U with Merlin firmware (latest production version. I used the netstat tool that is a feature of the router GUI. I found a few listening sockets open, which I don't recognize:
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:5473 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:18017 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3394 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:7788 0.0.0.0:* LISTEN
I don't have any reason to believe that this behavior is specific to Merlin firmware, but that is what I have, so here I am in this forum. What are these sockets being used for? Can I close them?
Using nmap from a machine on my LAN, I also see that ports 515/tcp and 9100/tcp are open. These ports generally support printing services, which I don't use on this router. I would like to close these ports too. Possible?
Upgrade to 384.6. Netstat now supports the -p flag, which tells you which process is bound to each port/socket.
  • Like
Reactions: kfp
Thanks Merlin. Here is the improved list of listening ports. I removed mention of ports that are only open for localhost. I also removed expected ports such as 53 (DNS).
What remains still looks like a lot. If anyone knows how to close off unused ports, please post.
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:5473 0.0.0.0:* LISTEN 524/u2ec
tcp 0 0 0.0.0.0:18017 0.0.0.0:* LISTEN 204/wanduck
tcp 0 0 0.0.0.0:3394 0.0.0.0:* LISTEN 524/u2ec
tcp 0 0 192.168.0.1:515 0.0.0.0:* LISTEN 525/lpd
tcp 0 0 192.168.0.1:9100 0.0.0.0:* LISTEN 525/lpd
tcp 0 0 0.0.0.0:7788 0.0.0.0:* LISTEN 343/cfg_server
tcp 0 0 192.168.0.1:3838 0.0.0.0:* LISTEN 525/lpd
udp 0 0 0.0.0.0:9999 0.0.0.0:* 256/infosvr
udp 0 0 0.0.0.0:42000 0.0.0.0:* 212/eapd
udp 0 0 0.0.0.0:45881 0.0.0.0:* 252/avahi-daemon: r
udp 0 0 0.0.0.0:67 0.0.0.0:* 247/dnsmasq
udp 0 0 0.0.0.0:46164 0.0.0.0:* 126/syslogd
udp 0 0 0.0.0.0:5474 0.0.0.0:* 524/u2ec
udp 0 0 0.0.0.0:18018 0.0.0.0:* 204/wanduck
udp 0 0 0.0.0.0:7788 0.0.0.0:* 343/cfg_server
udp 0 0 0.0.0.0:38000 0.0.0.0:* 212/eapd
udp 0 0 0.0.0.0:59000 0.0.0.0:* 212/eapd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 252/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 252/avahi-daemon: r
udp 0 0 0.0.0.0:43000 0.0.0.0:* 212/eapd
The only things you might want to stop are the avahi-daemon (mDNS/DNS-SD) if you don't have Apple devices, and lpd/u2ec if you don't have an attached USB printer. If you make changes in the GUI it's likely that some of these services will restart. The other services are required.
# service stop_mdns
# service stop_lpd
# service stop_u2ec
They're all firmware-related services. You cannot "close them".
