VPN network with Router Asus
darkpollo
I am not sure if what i want to do can be done with the Asus RT-N66U, but maybe you can help me.
At the moment I have my own internet connection and also i have a personal VPN setup created using Hamachi.
With that i can connect from my two computers (laptop and normal) and switch between the vpn and direct connection from the browser (using a plugin).
I have also an AppleTV connected to internet and i would like to be able to use the VPN on it. But there is no config that can be made on the Appletv so i thought maybe i could use the Asus router for this.
What i want is to be able to switch between the direct connection and the VPN when i need to, maybe with a button or something, not sure if that is possible.
Any suggestions?
I am really new on the VPN stuff but i am not newby on computers and i know how to change a firmware or access to the router using ssh... so if the solution you think is complicated, thats fine. :)
Thank you!
