huotg01
Sometimes my large WD USB drive is seen as unmounted.
I just checked at boot time and there were these messages :
I remember RMerlin having this explanation in another thread :
Based on these messages, any suggestions ?
Thanks.
Dec 3 16:47:50 hotplug[947]: USB /dev/sda1(ntfs) failed to mount at the first try!
Dec 3 16:47:51 kernel: tntfs error (device sda1, pid 1239): parse_options(): Unrecognized mount option sparse.
Dec 3 16:47:51 kernel: tfat: fail_safe is enabled
Dec 3 16:47:51 kernel: tntfs: fail_safe is enabled
Dec 3 16:47:51 kernel: tntfs info: NTFS volume name 'My Book^Ep', version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Dec 3 16:47:55 hotplug[947]: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/My_Book
Dec 3 16:47:59 rc_service: hotplug 947:notify_rc restart_nasapps
As suggested, my disk was previously checked on a PC and everything was ok.Check the system log for any error message. If it's a large drive, it's possible that the filesystem is flagged as dirty, and it's taking a long time running a chkdsk on it. You could try plugging it back on your PC, running chkdsk on it, then plugging it back to the router.
Thanks.
