Isp unless you are running dot through the vpn tunnel somehow. Btw the exclusive mode sets the dns used by vpn to vpn dns.When using DNSoverTLS in Merlin router and exclusive VPN, do the dns resolvers (cloudflair, etc) receive the request from the VPNs IP, or from the local router IP? In other words, does DNSoverTLS go inside or outside the VPN?
@LuboknokIf you want to use the routers DNS over TLS in the tunnel just set this setting in the VPN client settings.Code:Accept DNS Configuration to disabled
You never lived nor acted in a censorship environmentThanks for all the answers, although the last two seem to contradict. I suppose there is no practical reason to use DNSoverTLS inside the VPN tunnel, but it would be another layer of encryption.
Welcome To SNBForums
