In the engenious bridge review, it is said
Isn't it the case that most vendors advertise speed based on the WiFi burst rate? That is so misleading to consumers. The net IP layer speed is often 60% or so of the burst rate - because of WiFi duplexing overhead, forward error correction, media access delays, and so on.
It is interesting to note that the EnGenius advertises the ENH500 with a max data rate of 300 Mbps, but with only 10/100 Ethernet connections, you're going to be limited to 100 Mbps for any connection that goes from the wireless network to the wired network. We'll see in the Performance section that the 10/100 port does in fact limit maximum throughput.
