Hi all,
I have started as IT specialist at an organisation which have chosen to limit their ports on their avaya switches to 100mb/s (which leaves us with a local network transfer of 10mb/s) and I find this unacceptable. I have asked to have the ports changes to auto negotiate and allow the device to choose what it wants. Any devices that have a problem with that could be set manually. I' am constantly told that the reasoning behind this was to stop the wifi network being saturated as the local server only has a 1gb/s connections to the lan.
I can't see any real reasoning to limit the network in this way ....
A quote from an email I received from central IT ( the guy showed an example recommend by Microsoft for remote machines access ... which has nothing to do with local lan speed ). Help me reply
Reasoning behind this as follows:
- Servers will still be on 1Gbps connections. The new ones have three Gbps connections ‘split’ between 5 VMs. Even if they had 10Gbps cards (they don’t) the switches from memory don’t have 10Gbps ports available for client use
- 1Gbps connections client side *may* hog the available bandwidth to the wireless clients; that was the prior reasoning by the comms team to downgrade the wired clients to 100Mbps
Contrary to the above performance may be increased if the switches are predominantly doing unicast traffic as opposed to multicast or broadcast; if the servers communication is switching quickly between clients as opposed to pushing to a group simultaneously I assume the connections will use the available bandwidth for that connection instance. My knowledge of exactly how this works in reality is at best hazy though and from second hand conversations with comms; I understand why Matt wants to do this properly as opposed to switching the clients to 1Gbps and hoping for the best.
The planned internet bandwidth increase to 1Gbps will help however.
One other thing to note, comments in teams regarding how 100Mb client connections are slow by today’s standards, these are the recommendations by Microsoft only last year.
https://docs.microsoft.com/en-us/windows-server/remote/remote-desktop-services/network-guidance
For internet access, *High* quality streaming on iplayer only requires 5Mbps (1.5Mbps standard)
Apart from perhaps SCCM imaging, I’d be surprised if your wired clients are hitting the 100Mbps limit often.
