twennywonn
FYI New update is out
I never had a reboot issue since launch. Range is decent on the 2.4GHz band but speed and throughout is hurting bad.What about 2.4Ghz isn't working? The range for me is on par with both the AC68U and R7000. I have 5 home media players that connect to it at all hours of the day and night and none of them have any problems.
More on topic, it appears the GUI-related reboots are fixed, at least for me.
http://forums.smallnetbuilder.com/showthread.php?t=17594
Are you trying to use 40Mhz channel widths?
I have my 2.4Ghz radio set to B/G only, 20Mhz channel width (channel 11). As I said, I have 5 media players on that band and all of them are able to stream at the same time. I'm easily maxing out the available bandwidth on the 2.4Ghz radio but that's with the speed fixed at 54Mbps. I wonder if there are issues with N/AC on 2.4Ghz?
Are people still buying the WRT1900AC?
EA6900 router + blue housing (w/ 4th antenna) + same buggy/crappy Linksys firmware = WRT1900AC.
No 40 MHz channel here. I'm tired of hearing this I am not a noob. I know about CH 1, 6 and 11 with over lapping. You have a $250 router running in B and G mode. Just get a cheap G router in that case.Are you trying to use 40Mhz channel widths?
Thread starter | Title | Forum | Replies | Date |
C | Cisco wireless 150ax AP firmware update. | General Wireless Discussion | 0 | |
R | how to remove padvan firmware | General Wireless Discussion | 0 | |
D | Latest firmware updates - important for access point? | General Wireless Discussion | 2 |
Welcome To SNBForums
