ZyXel Admin GUI Timeout
Veldkornet
Hey guys,
So I have a ZyXel GS1900-8 switch with the 2.10(AAHH.0)Co firmware on.
I've set it to receive a reserved DHCP address from my router, and I also enabled HTTPS for the GUI.
Now everything was working fine since I've had it for a few months, but yesterday I tried to login to the GUI and it just timed out... Even after a reboot, no success.
On the router, I can see that it does have the correct Reserved DHCP address, also if I log into my SNMP monitor it picks up all the info from the switch, I can ping it... It's just the GUI that seems to be dead. I tried the default IP address that it ships with anyway for the hell of it, but that also didn't help. Only thing I haven't done is a factory reset, which if possible, I'd like to avoid.
Anyone else ever have this problem? Any advice on how to fix it?
Hmm, so after rebooting the router, it seems to be working again.....
Weird...
N Rack mount ears for Zyxel GS1920-8HPV2 switch Switches, NICs and cabling 0
