12 and 13 channel wi fi
Boris8080
I have a router RT Ac66. I can not put 12 or 13 channel wireless 2.4 GHz. After applying the automatic settings exhibited. On the firmware 3.0.0.4_378.51_0 this function to work on newer firmware is not working
Was already discussed several times (a small search would revel the postings): Asus has wrongly limited the channels - you can get them back if you install the latest corrected Asus original firmware, you wait for Merlin to update his fork or you use the HGG fork which opens all channels - that's what I do (see footer)! :rolleyes:
