Hey I’m a new proud user of the ax88u although I got problems with the new software versions with poor 2.4 ghz range is it fixed with the new .18 version ? And are there some recommend settings for using the smart connect option? don’t like 2 different ssid, I just flashed to .14 and it seems 2.4ghz got better range but quite slow.
some1 got some solutions ?
Thnx in advance
Thnx in advance
