I have 2 ac68u routers. One has all my open connections to my ISP. I have Spectrum and get 200 mbps if I am wired or close on 5G. The the 2nd is my vpn router. When I connect via wired or wireless to my VPN server to NordVPN I get speeds of 25mbps average. When connected to the open router, wired or wirless, using the same NordVPN I get 100 mbps plus.
I followed this tutorial.
www.snbforums.com
How do I trouble shoot this? is there a missing config on my first router?
thanks in advance - haeffnkr
Tutorial - Asus Dual-Router Setup with one dedicated VPN-Router 2021
This tutorial will teach you how to set up a dual-router configuration with a dedicated VPN router behind another router (the primary router). This will work with any VPN-enabled router firmware, including DD-WRT, ASUSWRT (including Merlin), and Tomato. We will be using what is known as...
www.snbforums.com
