3.0.0.4.378_7410-gc160981 to 3.0.0.4_378_9235-g3c846c5 NO GO
netfortius
Subject says it all. Presently running:
and downloaded (after extraction):
RT-N66U_3.0.0.4_378_9235-g3c846c5.trx
When trying to manually install the image (verifying new firmware, from within the Asus provided GUI, fails as always) via file->upload, the process starts and works for a little while, then fails with the message:
"Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again."
TIA,
Stefan
Did you reboot the router with all USB devices disconnected first?
