378.53 OpenVPN will not turn on/off
wallaby32
May 18 11:44:52 openvpn[922]: /usr/sbin/ip route del 10.8.0.0/24
May 18 11:44:52 openvpn[922]: Closing TUN/TAP interface
May 18 11:44:52 openvpn[922]: /usr/sbin/ip addr del dev tun21 local 10.8.0.1 peer 10.8.0.2
May 18 11:44:52 openvpn[922]: PLUGIN_CLOSE: /usr/lib/openvpn-plugin-auth-pam.so
May 18 11:44:52 openvpn[922]: SIGTERM[hard,] received, process exiting
May 18 11:44:52 kernel: tun: Universal TUN/TAP device driver, 1.6
May 18 11:44:52 kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
May 18 11:44:52 kernel: device tun21 entered promiscuous mode
May 18 11:44:55 openvpn[978]: OpenVPN 2.3.6 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Apr 26 2015
May 18 11:44:55 openvpn[978]: library versions: OpenSSL 1.0.0r 19 Mar 2015, LZO 2.08
May 18 11:44:55 openvpn[978]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
May 18 11:44:55 openvpn[978]: Diffie-Hellman initialized with 512 bit key
May 18 11:44:55 openvpn[978]: WARNING: POTENTIALLY DANGEROUS OPTION --client-cert-not-required may accept clients which do not present a certificate
May 18 11:44:55 openvpn[978]: Socket Buffers: R=[87380->131072] S=[16384->131072]
May 18 11:44:55 openvpn[978]: TUN/TAP device tun21 opened
May 18 11:44:55 openvpn[978]: TUN/TAP TX queue length set to 100
May 18 11:44:55 openvpn[978]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
May 18 11:44:55 openvpn[978]: /usr/sbin/ip link set dev tun21 up mtu 1500
May 18 11:44:55 openvpn[978]: /usr/sbin/ip addr add dev tun21 local 10.8.0.1 peer 10.8.0.2
May 18 11:44:55 openvpn[978]: /usr/sbin/ip route add 10.8.0.0/24 via 10.8.0.2
May 18 11:44:55 openvpn[984]: Listening for incoming TCP connection on [undef]
May 18 11:44:55 openvpn[984]: TCPv4_SERVER link local (bound): [undef]
May 18 11:44:55 openvpn[984]: TCPv4_SERVER link remote: [undef]
May 18 11:44:55 openvpn[984]: MULTI: multi_init called, r=256 v=256
May 18 11:44:55 openvpn[984]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
May 18 11:44:55 openvpn[984]: MULTI: TCP INIT maxclients=1024 maxevents=1028
May 18 11:44:55 openvpn[984]: Initialization Sequence Completed
Under status, OPENVPN is "Running" but I can't get it to switch off, I also can never select server 2 from the list. The whole thing is kinda wonky? what is going on with OpenVPN?
Also, when OpenVPN is running, it breaks the PPTP VPN.
Did you skip doing the factory default reset after loading the code? There was a change in the nvram variable that controls the autostart of the VPN servers a couple of releases back that needs to be initialized.
Sometimes it can be tough to know when a reset is absolutely necessary (it's always the safest thing to do). IMHO if you are moving between successive levels, check the release notes as to whether a reset is necessary. If you are moving more than one level, or changing code streams (ie from ASUS OEM to Merlin or the reverse) you should do a factory reset to avoid problems.
I did a factory reset right after the beta version, was it 374.51? I don't remember, but anyway, I did a factory reset again with the current firmware. Still a no go with Open VPN. I guess let me start with the obvious issue, are there specific instructions for starting the OpenVPN with this firmware?
