382 custom build
oldgringo
What should I set to properly build 382 (5.02hnd) git for ac86u? I tried the same method like 380 but it always ends with fail. Thanks.
Could somebody help with this? It always ends just before the kernel build:
make -f ./scripts/Makefile.build obj=scripts/basic
rm -f .tmp_quiet_recordmcount
make -f ./scripts/Makefile.build obj=scripts/kconfig ../../.config
make[5]: '../../.config' is up to date.
make -f ./scripts/Makefile.build obj=scripts/kconfig oldnoconfig
scripts/kconfig/conf  --olddefconfig Kconfig
../../bcmdrivers/Kconfig.autogen:2: syntax error
Kconfig.bcm:1336: missing end statement for this entry
Kconfig:15: missing end statement for this entry
../../bcmdrivers/Kconfig.autogen:1: invalid statement
Kconfig.bcm:1338: unexpected end statement
Kconfig:20: unexpected end statement
scripts/kconfig/Makefile:84: recipe for target 'olddefconfig' failed
make[5]: *** [olddefconfig] Error 1
Makefile:565: recipe for target 'oldnoconfig' failed
make[4]: *** [oldnoconfig] Error 2
It's just a git clone, no changes. I am probably missing something here.
The RT-AC86U requires bash to properly build (it's something that Broadcom changed in their SDK). You might need to change /bin/sh to link it to bash instead of sh/ash.
The bash was the reason, thanks. Now I end on this:
scripts/Makefile.build:258: recipe for target 'scripts/mod/empty.o' failed
make[6]: *** [scripts/mod/empty.o] Error 127
scripts/Makefile.build:423: recipe for target 'scripts/mod' failed
make[5]: *** [scripts/mod] Error 2
It seems like a toolchain problem. I can see in log that /opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-gcc cannot be found but all is there with proper attributes.
Edit: It work's under older version of Ubuntu.
