384.3 release SSL certificate replacement missing
Roofuzz
Hi there,
I've just updated my RT-AC88U to 384.3 release build, and i am not able to find the certificate upload/replace feature within this release.
I am using a SSL certificate on my AC88U but as with all firmware updates i need to re-upload the certificate in order to use SSL. Am i missing the section where to upload my SSL certificate to the unit or has it been removed?
Normally i would go to Administration->System and then in the lower section there would be the SSL certificate details and option to replace/upload a certificate. Now it isn't there.
Thanks for the replies.
It's present on my AC3200 . Try power cycling the router . Leave router power button turned on , pull plug from wall socket , leave for 2 minutes then power on again. Only other test is a factory reset.
It has been moved to the WAN --> DDNS tab going forward. Asus moved it here to work with the new Let's Encrypt stuff they are doing.
Ahh so there it went off to. I've looked everywhere but there.. since the name doesn't have anything related (in my point of view) with certs or anything.
Anyway, thank you! Found it and my cert is up and running again!
Thanks!
