386.1 wifi setup AC-88U and 2 x AC-68U
teo1966
hello
i search over the forum for the optimal wifi setup what is the best setup i read many different tips i have questions i cant find this settings which combination are good
i have 1 x ac-88u and 2 x ac-68u in aimesh 386.1
i have the same ssid name on 2.4 and 5.0
in the settings whit aimesh
enable smart connect on or off ?
control channel auto or on a channel ?
roaming assistant enable or disable ?
wps on or off ( need i wps for aimesh 2.0 ? )
See the link below to follow the suggestions to get your network as fast, stable, and secure as possible.
Make sure you start with flashing the firmware you want, installed, and doing a full reset with the suggested settings.
Control Channel Setup 2021
when i use aimesh 2.0 whit merlin 386.2-2 what's good roaming assistant on or off ?
