386.1 Wifi time scheduling
I still having issues on version 386.1_2 on my brand new AX86U router with the time scheduling. I receive my new Asus router a few days ago and install it right out of the box the new merlin firmware 386.1_2.
Now the time scheduling does work but not all the time. It have trouble in the time ON/OFF time, when the time come to provide internet access (On time) to some client is does it but when the time come to close the internet access (OFF time) it does not do it all the time and the client still remain internet access.
If i restart the router it works after the restart and again until next schedule off time.
I also have an Ac86U router and there it works fine the issue is only on the Ax86U.
Another Issue on both routers (AX86U and on AC86U) is on the guest number 1. The parental control does not work there at all. I know you told as not to use Guest number 1 but i need it for the Aimesh i have. There the parental control does not work at all not even when you disable completely the internet access to some client the client still have full access?
